Go to Post Use checklists. If it's good enough for NASA, it's good enough for FIRST. - Rick TYler [more]
Unread 19-02-2010, 16:57
Ethan E Ethan E is offline
FRC #1683
Ethan E is an unknown quantity at this point
'Enhanced IO Missing' error
I'm trying to implement the Cyprus module in our code, but have not yet gotten it to work. After many errors trying to implement it myself, I used the default Java code 'EnhancedIOSampleProject.' However, when I download the code and enable the robot, I get the print statement "Enhanced IO missing" several times per second. I have updated the module to v2 code, and have all the DriverStation and cRIO updates. In the operator's console the IO module light is green, the Digital Input indicators respond to the inputs on the Cyprus module. I can't for the life of me figure out why the module isn't working. Any help is greatly appreciated.
Unread 19-02-2010, 22:03
Re: 'Enhanced IO Missing' error
The cypress module supports either compatibility I/O (implemented in the DriverStation class) or enhanced I/O (implemented in the DriverStationEnhanced I/O class). Since you are using the enhanced I/O example, did you choose enhanced I/O on the I/O tab of the driver station?
Unread 19-02-2010, 22:51
FRC #1683
That worked perfectly, thank you
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
Digitally Enhanced Scouting System, DESS falconmaster General Forum 1 16-04-2007 13:05
842's "Digitally Enhanced Scouting System" ChuckDickerson General Forum 6 06-04-2007 11:44
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
