Go to Post Cut it out with the paper airplanes! Frank hath spoken! - cgmv123 [more]
Unread 19-02-2010, 23:36
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
Panic moment
So, we think we are almost ready for ship date, when someone pouring over rules happens to notice R43 in section 8. Our design uses expanded metal on the 'floor' of our robot. And all components are fastened to it one way or another. Some components have rubber grommets, but not all. We also used duct tape to cover all edges of the expanded metal. Are we breaking R43?
Unread 19-02-2010, 23:46
Re: Panic moment
There is a similar discussion here: http://www.chiefdelphi.com/forums/sh...ad.php?t=83090
Unread 20-02-2010, 01:36
Re: Panic moment
A,
No, you are not in trouble. The rule relates to the fact that the chassis of the Crio and the camera are both tied to the negative power lead of the battery. When these devices are mounted on the frame of the robot, then the frame becomes tied to the negative terminal of the battery. Certain sensors are also wired this way and the KOP sensor boards can contact the frame if not properly mounted. If you are worried then follow the procedure in the link above to find out for sure.
Rumor Panic Molten Rumor Mill 27 07-03-2008 16:46
TEAM 2120 UK, MAJOR PANIC HELP!!! campsmount Robot Showcase 21 22-02-2008 10:29
Proudest Moment shyra1353 General Forum 81 17-04-2005 21:31
Temporary Panic Nate Smith Chit-Chat 1 01-06-2001 11:20
