Go to Post Either way... woop! FRC is awesome! - Steven Smith [more]
Unread 20-02-2010, 01:51
voteforandy1 voteforandy1 is offline
FRC #3131
voteforandy1 is an unknown quantity at this point
Exclamation Weirdest issue with our robot!
I'm on team 3131 and as we were doing driving tryouts our robot suddenly developed an odd problem. Whenever we turn to the left, the jaguars seem to lose signal because they just go blinky lights. What's weird is that it's only when we turn left! At first the problem was only when yu turned maybe 45 degrees hard. And we kept repeating the problem to troubleshoot and it got so sensitive that now it loses signal really fast. We have narrowed out loose pwms, faulty jags, losing power to jags, and the obvious. Is this maybe a proggramming problem or a electrical problem. Before the problem started we were being fairly gentle with it. At leat we weren't shaking the electronics very bad. We left the meeting tonight with no answer and were coming back tomorrow to trouble shoot. Any advice? If there are any questions then just ask and I'd be happy to answer. We are desperate!!! Thanks!
-Andy Hunt (Gladstone, team 3131)
Unread 20-02-2010, 01:57
reversed_rocker's Avatar
reversed_rocker reversed_rocker is offline
Alumni
AKA: Ken Condon
FRC #0706 (Cyberhawks)
reversed_rocker is on a distinguished road
Re: Weirdest issue with our robot!
we had a similar problem last year, turned out to be a faulty jag. sometimes when they go bad they will only run in one direction. if you wrote it in C++ or java you should post your code for people to take a gander at
Unread 20-02-2010, 02:00
FRC #3131
I'll check that, we didn't think about the jag only running 1 way. We will voltimeter it tomorrow. Any other advice anybody?
Unread 20-02-2010, 02:05
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
1. Have you changed to a new battery?
2. Have you checked your drivetrain on the right side (assuming tank drive) for any unwanted drag that might be stalling the motors and causing the jags to go into self-protect mode for 3 seconds?
3. What is your drive configuration?
4. Are you running dual cims on both sides and have you confirmed each individual motor is running?
Andy,
It could be a variety of problems including a low battery. Were the jaguars slowly flashing red? This is an indication of a fault, usually over current. It lasts 3-4 seconds before the jaguars return to function. Were they flashing yellow like they do when the robot is disabled, then the battery voltage was so low that the Crio went into voltage protect mode. Certain robot designs draw very high currents in turns. It is also possible that there is something wrong mechanically on one side or the other of the robot drive system.
Unread 20-02-2010, 02:09
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
What code/language are you using? If it is LabView are you using scalars in your programming?
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 20-02-2010, 02:20
FRC #3131
1. Yes, and it actually seemed to delay make the problem more tolerant(good) but then it quickly got worse and worse.
2. We did and there was a slight difference, but it actually seemed to be easier to turn on the right side, (the side that's pushing and causes the problem) so I think that's probably not the issue.
3. We are doing four cim motor tank drive.
4. Yes, and yes however our test consisted of looking whether both the lights changed to the right color but we should test the actual electrical outputs with a voltimeter. And about programming, I am on electrical team so I know very little about our proggramming however I will ask our head programmer that and ask for the file to post. I do know we are using labview however.
J_Beth J_Beth is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
J_Beth will become famous soon enoughJ_Beth will become famous soon enough
If the problem started when you were turning hard to the left and it got worse as you kept turning to the left, could it be that your joysticks have gone bad, or is that even possible.
"I Wanna Be A Robot Maker!!!!"
Unread 20-02-2010, 02:28
FRC #3131
Smile Re: Weirdest issue with our robot!
Andy,
SMART!!! I didn't think about the voltage turning off the crio or putting it in protection mode. I think that is the most likely problem considering what I've seen. It makes perfect sense for what's happening. And it would make sense that it would only happen turning to the right because we sanded our wheels down and I bet one side is still much rougher than the other which makes it tough to turn which take a lot of energy. I will definetly look into that tomorrow! Thank you a billion times, chief Delphi rocks!
Alumni
AKA: Ken Condon
the joysticks can become uncalibrated. they center themselves when you plug them into the driver station, if you accidentally bump them while you're starting up you can have a joystick thats not centered properly. i dont think thats the issue but its a problem thats good to be aware of
Unread 20-02-2010, 02:47
AKA: Justin Beth
well, i am not quite sure of how joysticks operate, if they use pots or something else to measure their location, but could a sensor have gone bad so that it no longer reads that the stick is going left?
Unread 20-02-2010, 11:53
Andy,
The Crio goes into protect when the battery voltage falls below 5.5 volts for some length of time. You can get a little insight to this if you watch the voltage reading on the drivers station. Voltage samples are not continuous but if you notice voltage running up and down in turns and getting as low as say 7 or 8 volts, the dips are likely much lower. Reboot of the Crio can take place if the battery voltage should dip to around 4.5 volts at which time the 24 volt regulator in the PD starts to cut out. You know how long the Crio takes to boot so this is a risky issue for competition. Tank turns with high friction drives and wheels, cause CIM motors to draw near stall current. That is 129 amps per motor.
Unread 20-02-2010, 12:36
FRC #3131
For some reason our classmate shows our battery voltage is at 0.01 at all times when enabled, but that can't be true. How do I fix that?
Unread 20-02-2010, 12:49
Zac Pilarski Zac Pilarski is offline
FRC #1711
Team Role: Electrical
Zac Pilarski is an unknown quantity at this point
how are you getting your voltage value
Unread 20-02-2010, 13:53
weinertj's Avatar
weinertj weinertj is offline
Time Lord
AKA: John Weinert
FRC #3131 (Gladiators)
Team Role: Student
weinertj is an unknown quantity at this point
I'm on the same team as Andy. Yes, we are using Labview, and we have scalars.
Issue with Color Tracking Example (C/C++) and with Counters, Encoders, and Ultrasonic BradAMiller Programming 3 19-01-2009 21:24
Playing with our robot with a TV remote DarkFlame145 Robot Showcase 9 13-01-2008 23:42
Going through Canada with our Robot - Advice? FoleyEngineer General Forum 8 11-10-2007 13:11
A small issue with our Mecanums AGWSPilot Technical Discussion 15 18-03-2007 02:11
The weirdest thing w/ duct tape... Matt Attallah Chit-Chat 70 11-03-2004 13:51
