Re: MMRambotics - 12.2 Second Bumper Change
That's a sweet system.
I do hope that that isn't your finished robot. Bumper must be back by the robot frame per: M. The entire length of the BUMPER backing must be supported by the structure/frame of the ROBOT (i.e. the backing material must not be in “free space” between or beyond attachment points) (see Figure 8 – 3). A good hit, at the top of your bumpers, could seriously bend your mounts. |
the mounts are about 1/2 way up the bumper, and the entire length is supported by the frame.
Although I agree that a hit at the top very well could damage the bumpers or frame. |
I'd be more concerned with the provision that bumpers must be securely mounted. I can't see the details of the system, but I'd expect an inspector to want some assurance that your bumpers aren't going to release when someone runs into you. If you leave a bumper on the field during a match, expect to receive extreme scrutiny from inspectors and an order that you make sure it can't happen again.
The bumper system is very robust. Even a horizontal blow from below will not likely dislodge the bumper. The means by which the bumpers butt up against each other (45 degrees) creates a solid bumper "unit" with the bumper structures "supporting each other" as well as the frame.
| MMRambotics - Week Five Video | seannoseworthy | Robot Showcase | 7 | 17-02-2010 01:39 |
| MMRambotics - Bumpers :D | seannoseworthy | Robot Showcase | 3 | 10-02-2010 22:43 |
| MMRambotics - Week Four Video | seannoseworthy | Robot Showcase | 3 | 07-02-2010 22:34 |
| pic: MMRambotics - Electronic board and bumper mounts | seannoseworthy | Extra Discussion | 14 | 31-01-2010 20:00 |
| digital inputs lag 0.5-1.0 second before registering change | colman77 | Programming | 6 | 17-02-2006 12:40 |
