Go to Post When all you're holding is a hammer, every problem looks like a nail. - artdutra04 [more]
Unread 20-02-2010, 00:21
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
FRC #2200 (MMRambotics)
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy
Lightbulb MMRambotics - 12.2 Second Bumper Change
Hi,
Here is a short clip of out bumper mount system, the bumpers are able to be changed in 12.2 seconds by four people.
-Sean
Unread 20-02-2010, 07:20
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: MMRambotics - 12.2 Second Bumper Change
That's a sweet system.
I do hope that that isn't your finished robot. Bumper must be back by the robot frame per:
M. The entire length of the BUMPER backing must be supported by the structure/frame of the ROBOT (i.e. the backing material must not be in “free space” between or beyond attachment points) (see Figure 8 – 3).
A good hit, at the top of your bumpers, could seriously bend your mounts.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 20-02-2010, 08:10
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
the mounts are about 1/2 way up the bumper, and the entire length is supported by the frame.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 20-02-2010, 09:13
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
*highlight Mine* The length is supported, the entire height isnt (and isnt required to be).
Although I agree that a hit at the top very well could damage the bumpers or frame.
___________________
- Tennyson, Ulysses
Unread 20-02-2010, 09:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'd be more concerned with the provision that bumpers must be securely mounted. I can't see the details of the system, but I'd expect an inspector to want some assurance that your bumpers aren't going to release when someone runs into you. If you leave a bumper on the field during a match, expect to receive extreme scrutiny from inspectors and an order that you make sure it can't happen again.
Unread 20-02-2010, 11:21
They stay on very well, In this photo there is a spring that is not shown but it is where the blue arrow points. When you push up on the bolt towards the bottom of the frame the the bumper slides out as shown here
Unread 20-02-2010, 12:38
OptimusPrime's Avatar
OptimusPrime OptimusPrime is offline
FRC #2200
OptimusPrime is a splendid one to beholdOptimusPrime is a splendid one to beholdOptimusPrime is a splendid one to beholdOptimusPrime is a splendid one to beholdOptimusPrime is a splendid one to beholdOptimusPrime is a splendid one to beholdOptimusPrime is a splendid one to behold
The bumper system is very robust. Even a horizontal blow from below will not likely dislodge the bumper. The means by which the bumpers butt up against each other (45 degrees) creates a solid bumper "unit" with the bumper structures "supporting each other" as well as the frame.
Unread 22-02-2011, 07:53
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Those links are not working now. Can you get your pictures into CD?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
MMRambotics - Week Five Video seannoseworthy Robot Showcase 7 17-02-2010 01:39
MMRambotics - Bumpers :D seannoseworthy Robot Showcase 3 10-02-2010 22:43
MMRambotics - Week Four Video seannoseworthy Robot Showcase 3 07-02-2010 22:34
pic: MMRambotics - Electronic board and bumper mounts seannoseworthy Extra Discussion 14 31-01-2010 20:00
digital inputs lag 0.5-1.0 second before registering change colman77 Programming 6 17-02-2006 12:40
