Go to Post Oh man... 20% skinnier, 40% dorkier, ... if that's what turns into one of our best mentors, I REALLY need to find a new hobby. ;) - Rich Kressly [more]
Unread 20-02-2010, 00:23
spaztec's Avatar
spaztec spaztec is offline
Electrical Pit Crew
AKA: Luke
FRC #0069 (Hyper)
Team Role: Electrical
spaztec is an unknown quantity at this point
Send a message via AIM to spaztec
Powering the speed controller outputs
SCENARIO:
Powering a motor wired to a speed controller from the two output screws with a battery + alligator clips.
I will be running the motor directly to a battery through the screws+terminal on the speed controller.
Does anyone know if this would damage the speed controller in anyway? Having power run into the output terminals on the speed controller?
This is being done to shift some motors powering a winch.
2007 Boston Regional Champion
2005 California Regional Champion
2005 Connecticut Regional Champion
2004 California Regional Champion
2004 NH Regional Regional Champion
2002 Connecticut Regional Champion
2001 Connecticut Regional Champion
Unread 20-02-2010, 00:29
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Powering the speed controller outputs
Is this a Victor or a Jaguar?
I've never tried it with a Jaguar, but can tell you things like this happen all the time. Every time you backdrive a motor, the back-emf's generated by it will power the speed controller. That means, when you push your robot across the floor, you are backfeeding power into your speed controllers. They should be able handle it. I would hope this is not your method for removing the robot from the bar, as this would probably not be legal, since <r20> requires robots to not be powered up when removing them from the tower.
Kettering Motorsports
Unread 20-02-2010, 00:36
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Exclamation Re: Powering the speed controller outputs
Careful! We did this in the offseason to test some motors, and we ended up with two burned out Jaguars. I'm not an electrical person; I can't explain why. All I know is that we fried 'em. That was a very expensive lesson for us.
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 20-02-2010, 01:14
Luke,
Under the rules you may not affect a motor with a custom circuit, which is what it sounds like you are asking. If you are asking if you can add something in parallel with the output side of the controller you cannot do that on a competition robot. In general practice, the speed controller is not protected from changes in the load side power. Damage to the controller is likely, almost a guarantee.
Unread 20-02-2010, 08:38
spaztec's Avatar
Electrical Pit Crew
AKA: Luke
FRC #0069 (Hyper)
This will not be used in the field, and this is something to be done in the pits. We want to be able to reset the winch system without turning the whole control system on.
Unread 20-02-2010, 08:50
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Is it really that big of a deal to turn the system on and wait a few moments at the same time checking out the rest of your robot thus not worrying about damaging any component of your robot?
Unread 20-02-2010, 10:25
spaztec's Avatar
Electrical Pit Crew
AKA: Luke
FRC #0069 (Hyper)
The winch system needs to be reset once we bring it into the pits. Turning the whole control system on takes up more time.
Unread 20-02-2010, 11:45
Here is a radical idea for you. Use some Power Lock connectors between the controller and the motor. Then simply disconnect the motor connector and insert a power device of your choosing to rewind the motor. We have taken a 12 volt battery operated drill and added external wires with Power Locks on them to test motors and reset motor operated devices in the past.
Unread 20-02-2010, 11:55
Great solution! I've seen this done in the pits (by team 192) and I thought it was the neatest thing ever.
Unread 20-02-2010, 22:19
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
We use the Anderson PowerPole series for these connections - you can see them here - they're the blue connectors. It's pretty easy from this to plug a battery straight in, or even to just take the lead from the PDB and stick it in the lead form the motor for a quick short cut with a powered on robot.
Unread 21-02-2010, 05:37
DonRotolo's Avatar
Back to humble
FRC #0832
Just remember to use some kind of protection device (fuse, breaker) between your power source (likely a battery) and the motor, as close to the battery as practical. It can really ruin your day when a battery output gets a short circuit and all that's protecting it is a piece of #6 wire.
FRC Robot Controller/Speed Controller RoarRoar Control System 3 17-01-2008 10:41
limiting voltage to the speed controller team877 Programming 7 06-02-2007 16:28
Vex controller - outputs not working jrecht FIRST Tech Challenge 2 06-02-2006 23:26
Powering Robot Controller without breaker panel, etc. geeknerd99 Electrical 14 15-01-2006 21:23
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
