Go to Post Mind you, the Q&A forum and competition officials DO take precedence over my opinion. - dtengineering [more]
Unread 19-02-2010, 10:57
K Lenox's Avatar
K Lenox K Lenox is offline
I AM GOD IN GEARS OF WAR!!!!
FRC #2632 (Comets Unleashed)
K Lenox is an unknown quantity at this point
Kicking Clarification???
So I have been informed by another team that we are only allowed to kick the ball every 20 seconds and i havent found anything in the manual. If anyone knows anything about this rule, please let me know.
[font="Times New Roman"]
You never saw this message
You never read this
You will read the next available object within sight
Why are you still reading this???  Begone with you!!!
[SIGPIC]
Unread 19-02-2010, 11:01
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Re: Kicking Clarification???
The rule is 2 seconds, not 20. You must wait at least 2 seconds between kicks. Probably a typo on your friend's part. This rule is in the manual, though I don't know the exact number off the top of my head.
Cold Fusion's 10th Season
Unread 19-02-2010, 11:03
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Would be funny (or not) if you only kick ten balls per match...
But, if your kick mechanism extends outside BUMPER ZONE, you'll have to wait 2 seconds between each kick!
Unread 19-02-2010, 11:04
GaryVoshol's Avatar
Cogito ergo arbitro
Rule <G30-a>. And notice that it only applies if your kicker goes outside your FRAME PERIMETER. If it stays inside, there is no limit on kicking frequency.
(since 2004)
Unread 19-02-2010, 11:07
sloteera's Avatar
AKA: Rafa
I'm sorry by have told BUMPER ZONE. It's FRAME PERIMETER the correct!
Unread 19-02-2010, 11:14
AKA: Mike
Yes, very true. Thanks for pointing that out.
Unread 19-02-2010, 11:15
K Lenox's Avatar
thanks, saved me a horrible game
You never read this
[SIGPIC]
Unread 19-02-2010, 11:33
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I think the goal of that prank was to get you to read the rules....did it work?
Unread 19-02-2010, 12:29
Just so everyone is sure...
<G30> ROBOT Volume – During a MATCH, no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, except as follows:
a. BALL Interaction Volume – Solely for the purposes of interacting with a BALL, MECHANISMS that are below the BUMPER may extend up to the BUMPER PERIMETER, for a period not exceeding two seconds. After returning inside the FRAMER PERIMETER, such MECHANISMS are not permitted to re-extend beyond the FRAME PERIMETER for at least two seconds.
Unread 19-02-2010, 13:29
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
This brings up something that has been on my mind for the past couple days.
The rules quoted above me have 2 different 2-second timers. So simply saying "2 seconds between kicks" is not entirely accurate (that is, if I'm interpreting them correctly)
The first timer starts when you break the plane of the frame perimeter, and the second timer starts when you retract back within the frame perimeter.
Unless your kicks take zero seconds, there's really no way to kick twice with only 2.0 seconds between them.
Which brings me to my reason for being in here ... our kicker is spring loaded. We have some "tethers" that will eliminate any chance of breaking out of the bumper zone, but immediately after the kick we will probably oscillate back and forth across the frame perimeter a few times before the grabber grabs it and brings it back for the 2nd shot.
At first, I was worried that we'd violate the first rule since our kicker will probably cross the frame perimeter a few times before we grab it again. After some head scratching, my team and I have surmised that as long as we reach out, grab, and retract the kicker within that first 2-second timer, then hold it inside for at least 2 seconds, then we're A-OK.
Thoughts?
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 19-02-2010, 14:25
K Lenox's Avatar
that should work but ars long as you find a way to keep it inside the frame perimeter for those 2 seconds.
You never read this
[SIGPIC]
Unread 19-02-2010, 16:32
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
Sort of. Our robot's kicker doesn't even extend outside the robot's frame. We could even kick a ball every .2 seconds with out being penalized, if that were possible.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 20-02-2010, 09:56
MrForbes's Avatar
AKA: Jim
This sounds illegal to me. The rule says
After the mechanism returns inside the FRAME PERIMETER the first time, it cannot go outside the FRAME PERIMETER again for two seconds. So....if it goes out, then comes back in, it needs to wait two seconds before going out again. I think you'll need to control the oscillations. Or try limiting the travel so it cannot go past the frame perimeter--we found that we would not gain significant kicking distance with the extra 3" travel, so ours does not leave the frame.
Unread 20-02-2010, 10:03
Ziaholic's Avatar
Elec/SW Mentor
AKA: Marc
(emphasis mine)
That's what I was worried about. My original concerns are exactly as you describe. I was later talked out of it by kinda' "lawyering" the phrase
... may extend up to the BUMPER PERIMETER, for a period not exceeding two seconds.
I was hoping that during that 2 seconds, a few back-and-forths across the line would be OK, then I'd hold it inside for another 2-second count to ensure compliance with the 2nd part of that rule.
Hmmm.
Unread 20-02-2010, 13:33
If y'all gotta lawyer the rule to be legal, then y'all should be reading the text at the beginning of Section 8.3:
When reading these rules, please use technical common sense (engineering thinking) rather than “lawyering” the interpretation and splitting hairs over the precise wording in an attempt to find loopholes. Try to understand the reasoning behind a rule."
2 seconds means 2 seconds. It doesn't mean "out for 1/8 second, in for 1/16 second, repeat until out of time, wait 2 seconds, do it all again".
Kicking while driving 1418VaeVictus NI LabVIEW 3 18-02-2010 06:37
Castrol Kicking Robot SuperJake Chit-Chat 1 06-02-2010 21:13
Kicking multiple balls? Hito Seika Rules/Strategy 6 13-01-2010 21:55
Effectiveness of Kicking vs. Pushing bobwrit Rules/Strategy 39 12-01-2010 20:20
Kicking a robot's bottom... archiver 2001 5 24-06-2002 00:17
