Go to Post We put our alumni to work. That either benefits all or drives them out for good. :) - Wayne C. [more]
Unread 06-02-2010, 08:09
gbf1991 gbf1991 is offline
FRC #3011
gbf1991 is an unknown quantity at this point
4 Motor Drive
Hello, our team is having trouble, and we need help. We're using a 4 wheeled drive (w/Mecanum wheels), but we can't figure out how to program it as a tank drive. Can anyone out there help us?
Unread 06-02-2010, 13:35
phencer42's Avatar
phencer42 phencer42 is offline
FRC #1517 (P4)
phencer42 is on a distinguished road
Send a message via MSN to phencer42
Re: 4 Motor Drive
Start with the given Simple Robot Template and add the import "edu.wpi.first.wpilibj.*"
Then add
    RobotDrive drive = new RobotDrive(1,2,3,4);
    Joystick leftStick = new Joystick(1);
    Joystick rightStick = new Joystick(2);
under "public class RobotTemplate extends SimpleRobot"
Then add
drive.tankDrive(leftStick,rightStick);
under "public void operatorControl()".
This will give you a tank drive system for a four motor robot with front left motor in port 1, back left in port 2, front right in port 3, and rear right in port 4 using the left joystick in port 1 and the right joystick in port 2. Best of luck
Study=No Fail
No Study=Fail
No Study+Study=No Fail+Fail
(No+1)Study=(No+1)Fail
Study=Fail
Unread 08-02-2010, 00:58
imcmahon01 imcmahon01 is offline
FRC #1143
imcmahon01 has a spectacular aura aboutimcmahon01 has a spectacular aura aboutimcmahon01 has a spectacular aura about
Re: 4 Motor Drive
There is a specific function built for Mecanum wheel drive that you may find useful called holonomic drive. Now, it's not tank drive, but it does provide videogame-like controls for left-right strafing:
in the RobotTemplate() constructor, as before:
m_robotDrive = new RobotDrive(1, 3, 2, 4);
m_rightStick = new Joystick(1);
m_leftStick = new Joystick(2);
and in teleopPeriodic()
m_robotDrive.holonomicDrive( m_leftStick.getMagnitude(), m_leftStick.getDirectionDegrees() ,m_rightStick.getX());
We got this code to work, and plugged the PWM cables in as such:
Front of Robot
1 2
3 4
Rear of Robot
The only thing to note is, in this configuration motors 2 & 4 need to have their Jaguar M- and M+ motor power outputs reversed to the motors in order to work properly. Otherwise, you could fix this issue in your code by using the setInvertedMotor() function on 2 & 4. You can see our robot in action here. Hope this helps!
Unread 20-02-2010, 11:01
/*P4bl0*/'s Avatar
/*P4bl0*/ /*P4bl0*/ is offline
FRC #0231
/*P4bl0*/ can only hope to improve
Question Re: 4 Motor Drive
what if were are using victors ? what does it need to be done on the code to use victors ?
Unread 20-02-2010, 17:41
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: 4 Motor Drive
Victors more or less = jaguars
Single Motor Drive Team2339 NI LabVIEW 1 04-02-2009 23:43
Tracking Servo motor with drive motor in Labview mbone206 Technical Discussion 5 28-01-2009 17:32
Motor drive function? Mike Programming 3 15-02-2006 11:55
Screw drive motor top dog Motors 7 01-02-2005 09:43
8 Drive Motor Robot Dan Izzo Motors 9 28-04-2002 23:08
