Go to Post YO DAWGS. I GOT THIS. - LiquidMagik [more]
Unread 20-02-2010, 11:20
ThisAintJeff's Avatar
ThisAintJeff ThisAintJeff is offline
FRC #1591 (Greece Gladiators)
ThisAintJeff is an unknown quantity at this point
Send a message via AIM to ThisAintJeff
Trouble with Limit Switches
alright, so weve got a limit switch set on our kicker right? It is set to normally open, and its supposed to stop everytime that the switch is closed. now i used the DIO Input on LabVIEW to do this, and i have it set up so that when its true the motors go forward, and when its false, the motors are set to off.. however, no matter what i do, the limit switch does nothing. is there something i am overlooking?
Unread 20-02-2010, 16:41
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Trouble with Limit Switches
it is probably not wired correctly, those things are pretty foolproof
wire ground and signal to the two terminals that short when the switch is closed - run this to a digital I/O input and use the DigitialInput class
it kinda has to work
Unread 21-02-2010, 00:14
You do have the switch connected between ground and signal, right? And your wires go to the COM and NO pins on the switch, right?
Because of the pullup resistors on the Digital Sidecar's DIO pins, a Normally Open switch will read True when it's not active, and False when it is, so it looks like you got that part correct.
How are you using the switch value to zero the motor control? Show us that part of your code; it sounds like it isn't working properly.
Unread 21-02-2010, 08:39
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
just to test, you could put some kind of indicator on the front panel of whatever you are doing to make sure you are getting values at all. (or just probe the DIO get boolean wire)
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 21-02-2010, 09:51
The default Dashboard shows the state of the DIO pins (it updates only twice a second).
Limit Switches Wicked NI LabVIEW 9 04-03-2009 17:21
Limit Switches popnbrown NI LabVIEW 1 10-02-2009 22:39
Using Limit Switches with the Arm iwin2000 Programming 3 18-02-2008 03:52
How to connect limit switches with pwm cables?????!!!!! jesusescobar Kit & Additional Hardware 4 18-02-2007 18:15
limit switches stephenthe1 Programming 28 11-05-2005 16:37
