#8
Re: Powering the speed controller outputs
Here is a radical idea for you. Use some Power Lock connectors between the controller and the motor. Then simply disconnect the motor connector and insert a power device of your choosing to rewind the motor. We have taken a 12 volt battery operated drill and added external wires with Power Locks on them to test motors and reset motor operated devices in the past.
| FRC Robot Controller/Speed Controller | RoarRoar | Control System | 3 | 17-01-2008 10:41 |
| limiting voltage to the speed controller | team877 | Programming | 7 | 06-02-2007 16:28 |
| Vex controller - outputs not working | jrecht | FIRST Tech Challenge | 2 | 06-02-2006 23:26 |
| Powering Robot Controller without breaker panel, etc. | geeknerd99 | Electrical | 14 | 15-01-2006 21:23 |
| How do you connect the speed controller fans? | Iain | Electrical | 7 | 31-01-2003 07:05 |
