Re: 2.1 screwed up our holonomic
You guys at NI are doing a great job, and we thank you.
However, mandatory updates to LabVIEW this late in the build cycle should not break existing user code, even if the changes are to add functionality or make the code match the documentation. The only exception would be a safety issue. In the specific case of the holonomic VI, the old VI should have been left alone, and a new VI, with a different name, should have been created. The old VI could be deleted after giving a month's notice to teams. Just my 2 cents. ~ |
We try not to make changes late in the game that will affect your code. In theory, the holonomic change should not have affected you. We made the holonomic VI polymorphic (can now choose a specific VI to better meet your needs). However, the default instance of the polymorphic VI is the same as the original before the update. Could it possibly be that you edited the original? That could have caused this problem.
I was afraid that the update would mess us up too but it didn't I posted our code in a post a while ago if you want to go look at it.
| OK, Humanity's screwed when they turn on the Large Hadron Collider | Michael Hill | Chit-Chat | 6 | 10-09-2008 16:59 |
| Q&A Forum Screwed Up? | Petey | General Forum | 2 | 10-01-2006 19:16 |
| Holonomic... | Greg Perkins | Technical Discussion | 2 | 02-02-2005 11:59 |
| Screwed up results? | TheFork | 3D Animation and Competition | 18 | 18-05-2002 15:47 |
| Time Screwed Up | Matt Leese | CD Forum Support | 0 | 21-06-2001 21:53 |
