Go to Post I swear, sometimes it seems like FIRST has got a room full of monkeys writing code. Maybe the monkeys should spend less time flinging fecal matter at each other and more time testing the code before posting it :-). - Kevin Watson [more]
Unread 16-02-2010, 11:27
gamemonk0 gamemonk0 is offline
John Nguyen
AKA: John Nguyen
FRC #0151 (Tough Techs)
gamemonk0 is an unknown quantity at this point
Cannot Connect to Camera through cRIO
When we connect to the camera directly from the laptop via crossover, we can get the feed by accessing its IP address (192.168.0.90) in the browser just fine.
However, when it's connected to port two of the cRIO, we can't connect to it, or get it to feed to the driver station.
We can deploy code just fine, and we have the latest (as in the update released literally yesterday) version of the driver station, gyro compass and all.
Can anyone give us some help or point us towards a guide or something, because I haven't been able to find one of those online either?
Unread 17-02-2010, 18:07
John Nguyen
AKA: John Nguyen
Re: Cannot Connect to Camera through cRIO
Problem resolved.
Unread 18-02-2010, 12:54
unobtainium-42's Avatar
unobtainium-42 unobtainium-42 is offline
Team President
AKA: Eric Eaton
FRC #0670 (Homestead Robotics Team)
unobtainium-42 is an unknown quantity at this point
It would be more helpful if you explained how you resolved it.
The network jack on our cRIO did not turn on. The camera needs a crossover cable. Then, apparently you can get it to work by using AxisCamera &camera = AxisCamera::GetInstance(); and setting the parameters (in the constructor).
Unread 19-02-2010, 00:09
John Nguyen
AKA: John Nguyen
So sorry.
We solved it by updating everything. It seems that, somehow, one of our freshmen had managed to update the driver station without the necessary LabView update. So once we got our hands on that and re-updated the driver station as well, we began to start getting camera feed. Hope this helps.
Unread 20-02-2010, 11:43
Safety3rd Safety3rd is offline
FRC #3140
Safety3rd is an unknown quantity at this point
Originally Posted by gamemonk0 View Post
So sorry.
now where do you find the updates and everything? what website do you go to or does the driver station have a link to check for updates.
Unread 20-02-2010, 12:44
sp33chy sp33chy is offline
FRC #3332
sp33chy is an unknown quantity at this point
Quick question... what parameters?
I do call getInstance() (java) but I didn't know I needed to set any other parameters? I can't get this camera to work so maybe thats what I'm missing?
Unread 20-02-2010, 15:38
FRC #3140
So sorry.
Unread 20-02-2010, 19:37
Team President
AKA: Eric Eaton
I'm not sure how you don't know where the updates are, they are mandatory and on FIRST's website:
http://www.usfirst.org/roboticsprogr....aspx?id=10934
Make sure the cRIO's port that connects to the camera turns on its LEDs so the camera has the potential to communicate. I believe this requires a crossover cable.
Include the following lines in the class inheriting SimpleRobot's constructor:
// we just got these lines from the example 2010ImageDemo
camera.WriteResolution(AxisCameraParams::kResolution_320x240)
camera.WriteBrightness(0)
After doing just that, our camera works great, even if it's disconnected or booting it will still eventually start the image feed when the camera goes online.
Cannot connect to cRIO from WindRiver Darkknight512 C/C++ 8 25-01-2011 19:42
Cannot connect Windriver to robot abpahl C/C++ 4 19-02-2010 08:28
Cannot connect to cRIO aybose Java 3 02-02-2010 22:20
I/O Board Cannot Connect Haragorn FRC Control System 2 14-01-2010 13:50
Cannot Connect to Axis Camera Wirelessly computerish Technical Discussion 4 11-01-2009 19:19
