Go to Post Bottom line - keep your passion for FIRST and don't let others spoil your fun! - Sean Schuff [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 20-02-2010, 15:37
TonyP TonyP is offline
FRC #2151 (Pythons)
TonyP is an unknown quantity at this point
-52007 in CAN Receive.vi persists
We continue to see the -52007 message after a cRIO reboot. We have verified firmware levels, at version 87, and can communicate with the BCD-COMM software.
We have tried two cRIO's and have set the comm port dip switch in both positions.
Is there anything else we might be trying?
We are using LabView and communicating through the cRIO serial port.
Thanks
Tony
Unread 20-02-2010, 21:36
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: -52007 in CAN Receive.vi persists
Do the jags drive? We get those errors on init but all of the jags still run.
Update to version 89, it fixes a bug with resetting IDs. Speaking of resetting IDs, plug it into BDC-comm and check everything. If 2 jags got reset then the system gets confused because 2 jags share IDs.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 21-02-2010, 21:20
FRC #2151 (Pythons)
Thanks
In the end I found a new version of the CAN robot example code posted on First Forge. Revision 39 posted on Feb 18 and it seems to have resolved all of the issues I was having.
Too bad that it only left me one day to get my steering code working.
Still two bugs left but I can fix them between now and the competition I hope.
Set computer to receive it's IP via DHCP? grosh FRC Control System 21 28-05-2010 16:33
Error -52007 duane CAN 9 08-03-2010 19:52
How many IR Boards did you receive? SpaceOsc General Forum 3 22-02-2008 16:17
pic: Maryland FIRST Mentors receive Governor Service Awards RoboMom Extra Discussion 1 18-04-2007 17:59
NJ Regional - Anyone like to receive us? Chuck[#1156] Regional Competitions 27 03-03-2004 02:58
