Go to Post Might change next year. Read the manual then too. - Billfred [more]
Unread 20-02-2010, 15:40
nikRbokRz nikRbokRz is offline
FRC #1683
nikRbokRz is an unknown quantity at this point
Installing LabVIEW - Activiation Code?
I understand it's pretty late in the build season, but our team has been programming in Java. I wanted to install LabVIEW just to test some things out, but I could not find the installation key that it requires.
I am currently running a trial version. Does anyone know where the installation key is located (I haven't found it on the "FIRST Competition Software" packet with the DVDs)?
Unread 20-02-2010, 19:45
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Re: Installing LabVIEW - Activiation Code?
The activation code should be on the sleeve that holds the installations CDs. In a pinch you can use this activation code L13R02010 - it's the one I set up for the beta.
However, you should eventually find your official code in case we need to turn off the beta code.
Unread 20-02-2010, 20:44
pSYeNCe's Avatar
pSYeNCe pSYeNCe is offline
Programaster
AKA: James
FRC #2010 (Lightning Bots)
pSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to behold
The official code for all teams is L13R00000. It was sent out in an email for our team, I forget if I got it from FIRST though... Meh.
Unread 20-02-2010, 21:20
JP Carlin's Avatar
JP Carlin JP Carlin is offline
FRC #2487 (Mechanical Animals)
JP Carlin is on a distinguished road
i had to use two separate codes to put in. one for the regular laptop we use and one for the classmate. the one for the laptop was included and was with the packet of programming stuff and the other one was the one that we had to use on the classmate was posted right before me.
Unread 20-02-2010, 21:23
pSYeNCe's Avatar
Programaster
AKA: James
We used the one that was on the packet originally, but like I said we got an email saying to use the one I previously posted... We were having some activation problems with the included one but if it worked for you then maybe our problem is sporadic.
error installing labview error 1335 jerometab NI LabVIEW 0 06-02-2010 18:17
Problem installing Labview on VISTA windell747 NI LabVIEW 1 01-02-2009 22:55
Have You Had Problems installing LabVIEW 8.0 Student Edition? Danny Diaz National Instruments LabVIEW and Data Acquisition 1 11-03-2006 08:44
Problem installing Labview Joohoo LabView and Data Acquisition 3 08-01-2006 10:51
