Go to Post I personally find the time I spend developing FIRST teams and FIRST as a whole the most fulfilling thing I have ever done in my life. - PayneTrain [more]
Unread 20-02-2010, 14:33
chris janney chris janney is offline
FRC #3266
chris janney is an unknown quantity at this point
HELP solenoid trouble
well folks, we have a problem. our solenoid has voltage going out of the tabs. but our solenoid isn't working. any advice from anyone would be extremely useful.
Unread 20-02-2010, 15:37
Carter12s's Avatar
Carter12s Carter12s is offline
FRC #2036 (Black Knights)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
Re: HELP solenoid trouble
This is a problem that a lot of teams are experiencing. Make sure that if you are using this years KOP solenoids that you have the solenoid breakout on the cRIO connected to the 24v output on the Power Distribution Board; this years solenoids require 24v to operate and if 12v are used the lights on the solenoid will change but the internal rod will not move.
Unread 20-02-2010, 16:01
atwig atwig is offline
FRC #0135
atwig is an unknown quantity at this point
If you are using the FESTO solenoids, they require at least 30psi to fire.
At least the solenoids that came in last year's kit did, I'm not entirely sure about this year's.
Help Solenoid Programming team2987 NI LabVIEW 13 20-02-2010 22:36
Solenoid Help aznbadboixx Pneumatics 0 15-02-2008 15:53
Solenoid Help Brigander Programming 2 14-02-2007 17:13
Help with double solenoid almsfan21 Pneumatics 2 30-01-2007 19:57
Double Solenoid Help doyler Programming 4 19-02-2005 11:36
