Go to Post If you are adult enough to be a participant in this program, then you are adult enough to act like an adult. - Beth Sweet [more]
Unread 20-02-2010, 15:46
sbelding sbelding is offline
FRC #3151
sbelding is an unknown quantity at this point
FESTO Leaking Air
When we connect our FESTO to air, and it is not energized, the exhaust side is open. Is that how it works? We have hooked it up to the compressor and we are getting air leakage out of port 4.
Unread 20-02-2010, 16:27
Speeder Speeder is offline
AKA: Mr. Don
FRC #0316 (LuNaTeCs)
Speeder will become famous soon enough
Re: FESTO Leaking Air
Make sure your air pressure to the valve is at least 35 psi. Some valves require pressure to properly seat or transfer the internal spool of the valve.
Unread 20-02-2010, 16:47
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
For festos it is 30 psi, but a valid point, also make sure you have everything hooked up properly. Port 1 is intake, Port 3 is exhaust, and Ports 3 & 4 are your outputs.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Leaking Solenoid? ygd Pneumatics 5 03-02-2010 00:31
Festo itay_ms Electrical 3 30-01-2007 09:08
Microwave leaking? sanddrag Electrical 8 30-08-2006 20:06
Are we allowed to use a Bimba air-to-air booster? Alex Minot Pneumatics 1 20-02-2005 22:32
Leaking piston? Bill Becker Pneumatics 6 23-03-2004 18:10
