Go to Post Patents are an issue of law which, alas, has little to do with engineering or common sense. - Mike Betts [more]
Unread 20-02-2010, 16:02
z.s.tar.gz z.s.tar.gz is offline
FRC #3242
z.s.tar.gz is an unknown quantity at this point
24V cRIO digital output help
The manual does not specify how to do this other than the alternate 'schematic'.
Can someone please point me in the right direction for using digital input/output on the cRIO?
Unread 20-02-2010, 17:05
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: 24V cRIO digital output help
I'm a little bit confused about your question. Which are you trying to figure out?
  • How to hook up a 24v Solenoid
  • How to hook up a 12v Solenoid
  • How to use the digital sidecar to attach I/O devices
  • Something else not here
Jacob
Unread 20-02-2010, 17:22
FRC #3242
We know how to hook it up according to the schematics, but from a C++ standpoint we don't know what to do. The manual only says for the digital sidecars and not the modules on the cRIO.
Unread 21-02-2010, 00:18
If you're talking about the NI 9472 Digital Output module, that's controlled using the Solenoid class.
24v Conflict with cRIO and Solenoid Carter12s Control System 4 14-02-2010 10:02
cRIO output problem alex42 FRC Control System 1 27-01-2010 22:28
DS Digital Input/Output dboisvert C/C++ 11 08-03-2009 17:50
24v Power Conector to from the PDB to the cRIO mcf747 Electrical 14 01-12-2008 19:19
digital output frequency Barth Programming 8 06-03-2005 21:58
