Go to Post A stack of hearing aid batteries can also read 13v, but they won't run a robot. - Alan Anderson [more]
Unread 20-02-2010, 17:27
hax0rm4n hax0rm4n is offline
All your base are belong to us
AKA: Andrew
FRC #3040 (Zero Wing)
hax0rm4n is an unknown quantity at this point
Hangs when trying to deploy Java code
Hi,
Whenever I try to deploy code to our robot, Netbeans hangs and says "No user-supplied RobotMain()". This is really frustrating, as I haven't been able to test my code !
When I check the robot, the code isn't on it.
Does anyone have a solution?
Thanks
Unread 20-02-2010, 17:38
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: Hangs when trying to deploy Java code
When it says that, you need to enable the robot
Unread 20-02-2010, 18:58
AKA: Andrew
Do you mean through the Driver account on the driver station?
Whenever I do that, it doesn't have any effect.
Unread 21-02-2010, 02:01
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Seeing a message that says "Information: No user-supplied robotMain()" is completely normal if you're using the SimpleRobot class. It's a little misleading, but it is what it is. It has nothing to do with the robot being enabled or disabled. It will show every time it starts up.
How are you checking that your code isn't running? Are you not seeing the behavior that you expected? Something has to be running if you see the message about robotMain().
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 22-02-2010, 17:08
ericarseneau ericarseneau is offline
ericarseneau is an unknown quantity at this point
Can you provide the code for the robot class you wrote? As stated, the output your getting is normal if you have not overridden the robotMain method, its an information message and can be ignored.
Cannot deploy code Patrick Chiang FRC Control System 18 16-03-2013 15:46
trying to get terminalc stuff to work in 2006 code Athena Programming 2 27-01-2007 21:28
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Trying to import Camera code into program without. Kingofl337 Programming 1 18-02-2005 00:43
Some things i'm trying to understand on Kevin's Accelerometer Code Squall Programming 2 03-02-2005 12:01
