Go to Post IRI: where egos go to die...uhm..I mean fly! - Koko Ed [more]
Unread 20-02-2010, 19:44
DustinWyke's Avatar
DustinWyke DustinWyke is offline
FRC #0973 (Greyhound Revolutionary Robotics)
DustinWyke has much to be proud ofDustinWyke has much to be proud ofDustinWyke has much to be proud ofDustinWyke has much to be proud ofDustinWyke has much to be proud ofDustinWyke has much to be proud ofDustinWyke has much to be proud ofDustinWyke has much to be proud ofDustinWyke has much to be proud of
Raw Voltage on Cypress
does anyone know the raw voltage on the cypress PSoC 3?
Unread 21-02-2010, 00:37
Re: Raw Voltage on Cypress
3.3v using the default jumper settings.
Unread 09-03-2010, 00:03
David Dawson's Avatar
David Dawson David Dawson is offline
Capt'n turned Mentor
FRC #3771 (Yooper Troopers)
David Dawson will become famous soon enoughDavid Dawson will become famous soon enough
Would that be enough to hard wire a few led's?
Unread 09-03-2010, 04:12
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
It's quite easy to wire up a few LEDs.
I haven't seen many teams driving LEDs directly from the PSoC board without using the HC outputs.
968 developed a LED driver board that uses small power transistors to switch our LEDs. This allows us to drive multiple LEDs(5 of them) without going over the PSoC limits.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 10-03-2010, 18:38
manderson5192 manderson5192 is offline
AKA: Matt Anderson
FRC #0948 (Newport Robotics Group: NRG (pronounced eNeRGy))
manderson5192 is on a distinguished road
My team is looking at wiring up a LOT of LEDs to its OI. I know the PSoC board is presently jumpered to give 5v and the LEDs are being driven directly from the digital outputs (I don't think from the high current (HC) ones). They're also looking to use some super-bright LEDs that I'm sure exceed the current-sourcing limit of the PSoC board.
So my real question: what is the BEST solution for wiring up a lot of LEDs on the OI?
Unread 10-03-2010, 18:42
How many, exactly? Are they all controlled independently?
Unread 10-03-2010, 18:55
AKA: Matt Anderson
If I remember correctly, they want to put a 7-segment LED display (or a row of LEDs) on to indicate the kicker "power level" they're requesting of the kicker (insert >9000 reference here...), individual LEDs to give camera feedback to the driver (one LED means they're aimed too far left, one means too far right, and a center one means they're ready to kick), a single LED to indicate that the kicker leg is wound and ready to release.
The idea of using "super bright" LEDs is that the driver doesn't need to wear an annoying, clunky HUD. Rather, it will be very obvious from peripheral vision and ambient light to know what the robot's state is (different color LEDs at different positions indicate different things).
Unread 10-03-2010, 19:09
AKA: Matt Anderson
An additional question: are we permitted to make an LED driver circuit, such that the cypress board sends a digital signal that turns the LEDs on, but they are powered from a small 12v battery on board the OI (I think this would required using a transistor)? I can't find anything in the rules that prohibits this, and I have a feeling this would be legal as per <R82>...
Unread 10-03-2010, 20:17
Why not just use the Dashboard for all this? Our custom dashboard has a kick power meter (ours goes to 11), an "armed" indication, camera feedback with directional indicators, drivetrain status, etc.
That scheme sounds like it would be very easy to put on the Dashboard.
Cypress board bls0620 Electrical 4 17-01-2010 23:22
Cypress soc? sp33chy FRC Control System 2 15-01-2010 08:58
Raw Camera Data WatersongX C/C++ 8 03-02-2009 09:20
Served Raw Chicken at Burger King. MattK Chit-Chat 19 10-11-2005 00:56
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 01-03-2002 08:55
