Re: How can you save the camera image
Thanks. I was thinking about using the avi stuff but haven't got time on the robot to test it. If that fails I'll try that.
The AVI files will not work on the cRIO. They use MS Windows DLLs to produce the file, and none of that exists on the cRIO. So, you should be able to use them on the DB. The benefit is that you can view it in a viewer. The downside is when you want to measure something to improve the robot, you now have another layer of noise from compressing, decompressing, then compressing into another form.
Greg McKaskle |
avi was not working on the db for me so I extended the number of images saved to 1 image every second for 220 images for the entire match.
| Can we use the camera image on Dashboard this year? | Jon236 | Programming | 1 | 11-01-2010 12:52 |
| How can you add more rom space to the cRIO? | Comatose | FRC Control System | 8 | 05-02-2009 21:16 |
| how far can you ride the ball? | PHSmom | General Forum | 6 | 18-02-2008 21:41 |
| How do you hook up the camera? | SpeakerSilenced | Programming | 18 | 16-02-2005 15:00 |
