Go to Post "FIRST" is not a verb (yet - give us time, and we will see what happens). - dlavery [more]
Unread 20-02-2010, 21:35
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Fix loop for control
For running the kicker, I need to have some delays. However, I also need the program to respond to driver input during this. My current code (Selection below) has to pause for the completion of the kick.
I'm not sure how to do it. Thanks for any help!
if (lastState == false && m_otherStick.getTrigger() == true) {
    trigger.set(Relay.Value.kForward);
    Timer.delay(1.1);
    Watchdog.getInstance().feed();
    trigger.set(Relay.Value.kOff);
    trigger.set(Relay.Value.kReverse);
    Timer.delay(1);
    shoot.set(true); retract.set(false);
    Timer.delay(.4);
    shoot.set(false); retract.set(true);
    lastState = true;
} else if (lastState == true && m_otherStick.getTrigger() == false) {
    lastState = false;
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
closed-loop torque (current) wheel control for mecanum Ether Programming 3 07-02-2010 00:54
Radio Packet loss + closed loop control system = lunging robot Dave K. Control System 5 20-02-2007 06:09
control loop frequency. Rickertsen2 Programming 1 12-01-2006 08:38
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
PID control loop/Encoder question Zee Programming 18 30-01-2004 23:14
