Go to Post If everyone spent half as much time reading and understanding the rules as they do complaining, arguing, and disagreeing about rules, we might not even be having this discussion. - AmyPrib [more]
Unread 20-02-2010, 12:19
Dawl Dawl is offline
FRC #2549 (Millerbots)
Dawl is an unknown quantity at this point
What wheels is your team using???
My team is messing around with different wheels, trying to maximize traction while still being able to turn and be agile. We have determined that all wheel drive plaction wheels givesall the traction in the world but no turning ability. We are wondering if we are just using the wrong drive system (4 Wheel Drive), or if it is just an incorrect choice of wheel (Rough Plaction). If anyone has opinions or suggestions we would appreciate it.
Thanks,
Team 2549
Unread 20-02-2010, 14:04
Re: What wheels is your team using???
bump
Unread 20-02-2010, 14:16
3015 kom2012 3015 kom2012 is offline
FRC #3015
3015 kom2012 is an unknown quantity at this point
Thumbs up Re: What wheels is your team using???
mecanum wheels. we made our wheels for our robot.
Unread 20-02-2010, 14:24
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
You may be able to find something here to help you out....
http://www.chiefdelphi.com/media/papers/1443
Unread 20-02-2010, 20:14
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
4 wheel drive depending on the layout (long and narrow) with high traction wheels will definitely not turn well at all. A wide layout 4wd should turn fine.
We are using 8wd with dropped center wheels with colson performa wheels.
Mentor 2415
Unread 20-02-2010, 20:30
dtengineering's Avatar
AKA: Jason Brett
You might find this white paper helpful. http://www.chiefdelphi.com/media/papers/1917
Understanding why some robots turn and others don't is a big part of making a successful drive train, and I've blogged a bit about it for my students here http://botshop.wordpress.com/page/2/
We're using an 8 wheel drive system, with the axles evenly spaced about 10.5" apart. We are using 6" IFI (VEXPro) Traction wheels with 1.5" wide roughtop tread on the middle two axles, and 6" AM "kitbot" wheels from 2007 and 2008 on the ends. The end axles are raised 1/4", so the end wheels don't contact the ground when we are on the flat.
The wheels are driven directly off the output shaft (we have the extended output shaft) of a 14.88:1 toughbox.
The performance is astounding. It outperforms EVERY drivetrain we've built, inlcuding a mecanum drive. I figure we can go from full speed to stop, turn 90 degrees and get back up to full speed in about the same time it took the mecanum to come to a stop and begin to strafe sideways.
Admittedly, the mecanum had a higher top speed, (12.75:1 driving 8" wheels) but it rarely reached it, and we do have a bit more weight to add to this machine, so the accelleration may drop off a wee bit.
This is our seventh year of building robots and we keep getting better at it, it seems, and I'm pretty sure after looking at what some other teams have built this year we can do better still. So good luck figuring out your drive and using that knowledge to form the starting point for your next 'bot.
Jason
Unread 20-02-2010, 21:35
hyperdude's Avatar
hyperdude hyperdude is offline
Techie.
AKA: Mike W.
FRC #2503 (Warrior Robotics)
hyperdude has a spectacular aura abouthyperdude has a spectacular aura abouthyperdude has a spectacular aura about
So far this year, we've gone with just 4 KOP "sticky" wheels. Now that today we got the robot actually working and driving around, kicking and not-quite-lifting, we realized 4 sticky wheels isn't going to cut it, with too much traction impeding our ability to turn (something I brought up way early in the season, but no one had cared).
Right now the plan is that Monday we'll replace two of them with "slick" wheels (the thought process is that they'll be front-left and back-right, or whichever two diagonal corners were the heaviest). I think that will make it drive awesome.
Unread 20-02-2010, 21:39
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
We've got two 6" IFI wheels, 1 1/2" traction on the front, and 2 of the KOP slick wheels for the rear. All are powered off 2 KOP toughboxes, each with two CIMS geared together.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 20-02-2010, 22:11
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Front-roughtop
rear-slick
...same on the other side
Unread 20-02-2010, 22:12
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
6" plactions in the front, dual 6" plastic omni's in the back. it goes over the bump both ways no problem (fits under the tunnel too).
Unread 20-02-2010, 22:17
KC1AJT's Avatar
KC1AJT KC1AJT is offline
Head Mentor
AKA: Patrick
FRC #6617 (Bellinghan High School Black Hawks Robotics Club)
KC1AJT is an unknown quantity at this point
6 wheel system with 2 omni wheels and 4 placton wheels on a pivoting drivetrain
http://www.youtube.com/watch?v=uRstQWId13k
http://www.youtube.com/watch?v=f6QmRkbvx-k
Mentor - Team 6617
_____________________________________________
Student Years - Team 61
2011 Boston Regional
2011 BAE Systems/Granite State Regional
2010 Northeast Utilities FIRST Connecticut Regional Finalist
2010 Boston Regional
2009 Archimedes Division
2009 Connecticut Regional
2009 Boston Regional Regional Winner
Unread 20-02-2010, 23:01
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
4 plaction wheels.
Unread 22-02-2010, 04:37
techedguy's Avatar
techedguy techedguy is offline
Technology Education, PFHS
AKA: Sal
FRC #4520 (Roboteknix)
techedguy is just really nicetechedguy is just really nicetechedguy is just really nicetechedguy is just really nicetechedguy is just really nice
See attached photo. 4 of these on individual gearboxes...but these took 4 weeks to design and fabricate in total. It's too bad the bumpers and struts hide all of it. Oh, and we've had to re-machine the center hub since this photo...so there is some shiny silvery aluminum showing on the ends of the sprockets. The metal was hitting concrete on occasion with the design in the picture. Nothing like taking it all apart and putting it back together for team unity and morale.
Salvatore Lorenzen, M.Ed, Ed.S.
Mentor/Coach/Teacher
I am not who I hope to be, but I am trying. I am giving it my all to improve me; and I’m thankful at the end of each day that I’m not the guy I used to be.
FRC #4520 - Misfit Toys
2012 Spokane Regional WFA
2009 Idaho GIANTS Award
What are you all using to hold down your control systems? JackknifeJustin General Forum 10 02-02-2008 12:24
CT Teams - What does your school system provide your team WDAtiyeh General Forum 5 05-03-2007 19:23
What drive system is your team using? dpick1055 Technical Discussion 22 27-01-2007 23:29
What kind of material will you be using for your arm/forklift? Atman Technical Discussion 35 31-01-2005 15:28
What kind of materials do you use for your wheels? Alex Cormier Technical Discussion 1 24-01-2005 19:19
