Go to Post There can never be enough help, unless there's too much help. - Joshua May [more]
Unread 20-02-2010, 21:40
superstretch superstretch is offline
FRC #0417
superstretch is an unknown quantity at this point
Joystick accessors
Hi, I hope someone can clear up some confusion the WPI users guide is causing me. What is the difference between someJoysick.GetX(), someJoysick.GetAxis(kXAxis), someJoysick.GetRawAxis(kXAxis)?
Unread 21-02-2010, 09:20
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Joystick accessors
nothing, they all get the X axis. I recommend the GetX() function, but if you need to be able to dynamically set the joystick axis you need to get, use the others
edit: GetRawAxis uses a number instead of the enum (kXAxis)
Watchdog.Kill();
1 joystick or 2? ChrisMcK2186 Control System 18 19-01-2007 23:42
joystick ? _GP_ General Forum 1 26-02-2004 23:10
Joystick rmmlg Inventor 0 15-02-2004 16:34
Joystick cammie825 Technical Discussion 1 15-01-2003 10:48
No Joystick archiver 2001 2 24-06-2002 01:14
