Go to Post The person that I would, without a doubt, would like to meet the most is my sanity. - lukevanoort [more]
Unread 20-02-2010, 21:01
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
pic: Holliston 2010 Robot
Unread 20-02-2010, 21:04
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1011
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
Re: pic: Holliston 2010 Robot
Wow! Looks like some heavy duty treads. How much do they weigh? Looks like you should have enough power.
Looks pretty good. Have you guys devised a good way to protect all of those precious electronics?
Other than that good luck.
Unread 20-02-2010, 21:05
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
That's a pretty good looking robot, but I'm a little worried about your treads. It's hard to tell the material from the picture, so I'm worried if you're in compliance with R08:
ROBOT wheels, tracks, and other parts intended to provide traction on the carpet may be purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no case will traction devices that damage the carpet or other playing surfaces be permitted. Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments. Anchors (i.e. devices that are deployed/used to keep one’s ROBOT in one place and prevent if from being moved by another ROBOT) shall not use metal in contact with the carpet to “stay put.” Gaining traction by using adhesives or Velcro-like fastener material is not allowed.
You need to be rather careful that you don't have any metal contacting the carpet.
Unread 20-02-2010, 21:56
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yeah, there will be a Polycarb cover over it.
The material is styrene butadiene rubber, Its held on with rivets that are sunk 1/8th of inch below the plane of contact and sealed with some thermoplastic.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 20-02-2010, 22:03
Imaginary Friend
AKA: Kevin Li
Team Role: Student
I'm not sure of the weight of the treads. But the robot comes in under 100 lbs.
Kevin Li
596 - Sciclones
Unread 20-02-2010, 22:08
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
Looks good.
How well can it turn?
Approximate top speed?
Range of kicking system?
(Hanging system?)
Unread 20-02-2010, 22:14
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Originally Posted by Vector MycroftH View Post
Looks good.
(Hanging system?)
I think it runs around 5 Feet Per second. It didn't seem to have any trouble turning on the tile floor of the school. The kicker travels about 15 feet. There's a winch underneath the electronics that goes with a hook and the scissor lift; it runs off a tough box and a CIM. We haven't tested the lifting yet though.
Kevin Li
596 - Sciclones
Unread 20-02-2010, 23:03
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Whoah. Get that thing on some carpet NOW. Tile floor and carpet are two entirely different things, and you may have a very nasty shock in store when you put it on carpet.
Our team did treads the first year. They were incredible when the bot was 60 pounds. When it was 150 pounds.... well... let's say they switched to wheels since just going straight back and forth wasn't really effective without being able to turn!
Unread 20-02-2010, 23:11
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yeah I expected that but the rubber seemed to grip decent on the carpet but not too much.
Kevin Li
596 - Sciclones
Unread 20-02-2010, 23:18
polehead3 polehead3 is offline
FRC #1625 (Winnovation)
polehead3 will become famous soon enoughpolehead3 will become famous soon enough
Send a message via AIM to polehead3
nice treads
Unread 21-02-2010, 01:38
Elizabeth Waters's Avatar
Elizabeth Waters Elizabeth Waters is offline
Elizabeth Waters will become famous soon enough
Are y'all planning on driving over bumps or going the tunnel route? It's difficult to judge the size of your bot from the picture. Is climbing the bumb even an option with such tread?
The tread is pretty sweet, though. Our team like many others took the mecanum wheel route.
Georgia Institute of Technology
BS Mechanical Engineering '16
2012-2014 | Volunteer
2012-____ | Dean's List Finalist, Lone Star Regional
2008-2012 | 624: CRyptonite
Unread 21-02-2010, 01:39
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Once we hack off the excess screw and guide rail it will fit under the tunnel. And we'll find out about the bump soon.
Kevin Li
596 - Sciclones
Team 706's 2010 Robot Demonstration Video reversed_rocker Robot Showcase 40 24-03-2010 13:39
pic: Team 241 2010 robot: Freedom 8 Dantvman27 Extra Discussion 10 21-02-2010 10:07
Team 217 2010 robot Mike Copioli Robot Showcase 24 21-02-2010 08:21
pic: Team 1322 2010 Robot Start Week 3 joeweber Extra Discussion 14 02-02-2010 18:04
pic: 2010 Team 1625 Robot Design Hint #0 elvis9110 Extra Discussion 17 28-01-2010 14:23
