Go to Post Programming team motto: If it doesn't work, use a bigger hammer. - WizenedEE [more]
Unread 20-02-2010, 23:10
Carter12s's Avatar
Carter12s Carter12s is offline
Team Cap
FRC #3374 (Robo-Broncs)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
WiFi Issues?
Hello i am having a problem linking to our robot. I have checked the signal strength at both terminals and both routers have signal to each other. I have re-run the instructions in the control manual and i still cannot get it to connect it was working perfectly until today. any help?
Unread 10-03-2010, 04:46
semiferger semiferger is offline
Junior Member
semiferger is an unknown quantity at this point
Re: WiFi Issues?
You have to install the barracuda wifi robot / spybot controller
We started barracuda wifi out by extending the wires coming from the motor by soldering on extra wire. Below is a picture of the Barracuda WiFi Robot / Spybot controller. This is what we will be using to control our robot.
After this we wanted you to take a look at the yellow wire from the motor that is connected to the terminal block. You can also see how the batteries are connected in series to power the Barracuda WiFi Robot controller. We connect the servo on the green terminal block. The red wire is connected to the third 7.2v batteries ground, as well as the servo's ground -- tying them all together. The white wire is the servo's signal wire. The Barracuda has two ports; each can individually be configured as a digital or analog input, a digital output or an Rc output.
WiFi in pits EHaskins Rules/Strategy 36 03-03-2009 15:38
wifi? compuwiz12 Scouting 5 19-01-2009 15:45
Wifi on Robots mogunus Programming 9 08-03-2006 07:30
Wifi Networks Eugenia Gabrielov Chit-Chat 4 17-06-2004 09:56
wifi at nats Alexander McGee Championship Event 7 14-04-2004 23:38
