Go to Post Someone wake me up the day of Kickoff. - Andrew Schreiber [more]
Unread 20-02-2010, 17:52
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Robot control cuts out
We noticed as we have been practicing that every so often, usually when were pushing our cim motors to the max, the control to the robot cuts out and were stuck for a couple seconds.
Someone mentioned it could be a programming bug or something, but has anyone else had this??
(were using all 5 cims)
Unread 20-02-2010, 18:21
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
Re: Robot control cuts out
We were experiencing this today during some driving practice with a few other teams today in Quincy, Mass. What it ended up being was nothing more than wireless interference, as soon as we changed our wireless channel the cims stopped cutting out. Could this be happening to you?
Unread 20-02-2010, 18:40
AKA: Brandon Liatys
don't know how to change the channel, but it was just us driving, no other teams.
Unread 20-02-2010, 18:54
360skier 360skier is offline
RTFM!!
AKA: Eric A.
FRC #1334 (Red Devils)
360skier is an unknown quantity at this point
If you've been driving it a long time, it's possible that your battery has worn out.
I believe I heard somewhere that the cRIO cuts off all outputs when the voltage supplied to it drops below a certain value.
You can test this by looking at the battery indicator on the DS while driving the robot. If the voltage tends to fall down to 9 volts or less when running full steam, then it's probably time to change the battery.
Unread 20-02-2010, 18:56
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
How long does control cut out for? Are you using a fully charged battery?
It may be that when you are powering all your CIMs, the cRIO power drops below the cutoff and power cycles.
Unread 20-02-2010, 20:19
Where do you have your wireless bridge's power plugged into? Does it match the Power distribution diagram?
What do the lights on the speed controllers do before, during, and after this happens?
Unread 20-02-2010, 20:22
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Is your wireless bridge securely connected to it's dedicated power source on the PDB, as stated above?
When the robot stops moving, does the Driver Station maintain communications with the robot?
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 20-02-2010, 21:23
Speeder Speeder is offline
AKA: Mr. Don
FRC #0316 (LuNaTeCs)
Speeder will become famous soon enough
All through build, our Robot WIFI has been bothered by other wireless networks causing interruptions/interference around our campus. It really seems to affect the DS. When we've lost communications, all system devices except the DS are pingable (is that a word) from another PC. We didn't have any noticeable effects last year when the DS was hardwired, the only configuration that has changed from 2009.
Unread 20-02-2010, 21:26
pSYeNCe's Avatar
pSYeNCe pSYeNCe is offline
Programaster
AKA: James
FRC #2010 (Lightning Bots)
pSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to behold
I'm fairly sure that's correct, as we had one of our batteries dip very low and the robot simply ceased to move at all. Other than that, I have no solutions, sorry
Unread 21-02-2010, 00:14
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
...you could also be tripping the breakers...?
I would look into that...and I am surprised that I was the first to mention it lol
when our controlls cut out due to power drain, it only shuts out for about half a second...
we too are using all 5 cims...
sometimes when pushing full force, the orange light on top of the robot turns completely off haha
I am concerned about power this year.
Nobody really saw how the CRIO and the power distribution took to the harsh world of high current draw...last year we were all sliding around simply spinning the wheels haha
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
Unread 21-02-2010, 02:36
The Crio has a voltage brownout mode where all outputs are disabled. This occurs when the battery is about 5.5 volts and it sensed through the jumper you must add to the analog module in slot 1. This is performed in anticipation of the battery falling to the point at which the 24 volt power supply becomes unstable. Should the battery voltage fall below 4.5 volts the Crio may reboot.
Unread 27-02-2010, 23:59
AKA: Brandon Liatys
We had fresh batteries, everything is wired right (as far as I know), and it dosent say were loosing comms or watchdog.
Unread 28-02-2010, 02:47
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
What type of motor controllers are you using?
If you are using Jaguars, when you pull more then 60 amps for more then 2 seconds, it disables the motor for ~3 seconds.
If you are running on CAN, you can set the time for fault conditions down to about half a second.
Which is a little better for your drivers,
(Just imagine them shouting about how they would lose control for some period of time).
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 28-02-2010, 09:43
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I'm surprised you're the first to mention it too.
If the robot is cutting out when you're pushing, stalling, or near stalling any of the cims, it wouldn't surprised me if you're tripping your auto-resetting (3 seconds) breakers, or that you are tripping the internal protection if you are using jags.
If you're dumping low enough to cause the Crio to reboot, it's going to take quite a while for it to reset and regain connection. The bridge will take slightly less time, but it will take time.
So next time you are driving, watch your drivers station. When the robot stops, does it reflect a loss of communication (no robot) or a loss of code (no robot code), or does it stay static? That will lead you in the right direction.
If robot communication is not dropped, then I would start considering that you might be pushing the breakers too hard, or your digital sidecar might have the power wired incorrectly.
Unread 28-02-2010, 11:03
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Is the crio updated to the latest one? Our robot was cutting out for a second here and there until they updated it.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
For those who think we need more power out of the control system... Dave Flowerday FRC Control System 3 26-03-2009 17:07
Radio cuts out, student's foot run over grantf Control System 30 25-02-2007 00:53
Budget Cuts khssoccer16 General Forum 12 16-09-2002 17:55
