Go to Post It's your duty in FRC to your teammates and alliance partners to put the most competitive robot possible on the field. - Chris is me [more]
Unread 20-02-2010, 23:13
slicer800 slicer800 is offline
FRC #0569
slicer800 is an unknown quantity at this point
Crio and compressor question
I can't figure out why the cRIO won't hold the program i use the cRIO tool and i check the box format controller and i also check the box that is right under the word labview (because it lists 3 different coding languages) and download it and it says download completed successfully but it does not hold, meaning it loses the program after we shut the robot off.
And does anyone have a program for the compressor loop because i can get the compressor to check when it reaches pressure once and shut off but after we use some of the air the compressor comes back on like it should but this time it does not stop and keeps going until we unplug it manually. (I can't figure out how to loop the process.)
~Team 569
Unread 21-02-2010, 00:24
Re: Crio and compressor question
To download your program permanently, do it from the LabVIEW Project Explorer window:
  • Under Build Specifications there is a file listed: FRC Robot Boot-up Deployment
  • Right-click on that file and choose "Build" (this will take a few minutes to complete)
  • Right-click on that file again and choose "Run as startup" (at the end of this you will be asked to reboot the robot)
  • Reboot the robot.
Unread 21-02-2010, 08:44
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
If you are using the compressor vi to start the compressor than that part is built into it. You don't have to do anything but start the compressor and let it run. The it will shut off automatically when the pressure gets to around 120ish psi, and then turn back on when it needs to.
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Major compressor question star_lancer NI LabVIEW 3 16-02-2009 22:48
Air Compressor Question Jrocklz Pneumatics 4 17-01-2008 21:36
Air Compressor Wireing question Bochek General Forum 7 11-01-2007 21:34
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
compressor and light question... archiver 2001 5 24-06-2002 00:47
