Go to Post Seems decretive bumpers are the new rage now. I couldn't stand making them once, never mind twice. - Gregor [more]
Unread 21-02-2010, 00:24
IraGlass IraGlass is offline
FRC #2367
IraGlass is an unknown quantity at this point
Encoder-assisted Mecanum drive?
I'm having trouble with the programming for a Mecanum drive that runs straight. I can see how to use encoders to straighten out a tank/arcade drive, and my straightening code works fine forwards and backwards, but moving side-to-side or spinning messes up the code and just makes the robot twitch around. Is there some default code or other method to run an encoded Mecanum drive? Any advice is greatly appreciated!
Unread 21-02-2010, 00:57
dtengineering's Avatar
AKA: Jason Brett
Re: Encoder-assisted Mecanum drive?
We had two very talented programmers who figured out how to do this using interrupts on an IFI controller three or four years ago. I believe they calculated a desired speed for each wheel, then ran a PID loop to set the wheel speed. Aside from that, I don't actually know what they did, and am afraid to touch the code for that robot lest we send it skittling across the floor out of control. It took a while to tune it.
Have you tried using the gyro to keep it traking straight?
Jason
Unread 21-02-2010, 23:53
Just curious, how badly does your bot behave with just open-loop voltage commands given to the 4 motors?
If it's ill-behaved open-loop, it's possible there's a weak motor or a friction problem with the drivetrain or mecanum rollers. Have you checked all the rollers to make sure they spin freely?
Unread 22-02-2010, 00:12
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
this is probably already considered: but just make sure your wheels are in the correct setup. i believe mechanums go in an "X" configuration? not positive though... also, maybe you would like to mention what language you are using. I cant help much, but it may be beneficial to the next guy reading this post
862 mecanum drive Wildcat Robot Showcase 0 15-02-2010 17:21
crab drive vs. mecanum drive system superbotman Technical Discussion 33 06-01-2010 03:09
Mecanum Drive - Help Smoking_Gun Programming 22 04-12-2007 20:51
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
