Go to Post It would be a lot easier if students would quit being so magnificent. Really. - JaneYoung [more]
Unread 21-02-2010, 05:57
Connor's Avatar
Connor Connor is offline
FTC #3768 (Crusading Cucumbers)
Connor is an unknown quantity at this point
[FTC]: RobotC Question
I was reading the FCS guide a second ago and i noticed that it said speciffically to install labview. Does this mean that robotC will not work with it? This is what we have been using all year and our competition is next week. Was it simply left out of the FCS guide or do we need to change all of our code. Please help clarify
"Never is just reven spelled backwards."
Unread 21-02-2010, 09:42
buddyb's Avatar
buddyb buddyb is offline
FRC #1885 (ILITE)
buddyb has a spectacular aura aboutbuddyb has a spectacular aura aboutbuddyb has a spectacular aura about
Re: [FTC]: RobotC Question
Our team uses RobotC and the FCS together easily. You have to have LabVIEW installed *on the computer running the FCS* because the FCS is made in LabVIEW. The language you program your robot in doesn't matter, as they all appear as the same to the FCS.
Good luck at your competition!
FRC - Team 1885 - Programmer.
Unread 21-02-2010, 10:52
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
There are three versions of the FCS installer and they are located on the FIRST web site:
http://www.usfirst.org/roboticsprogr....aspx?id=15924
The three versions of the FCS are:
1. FTC FCS Program - Use this version if LabVIEW is not installed on the computer.
2. FTC FCS Windows Executable - Use this version if this season's version of LabVIEW is installed on the computer.
3. FTC FCS Mac - Use this version if you are using an Apple OS.
[FTC]: Buttons RobotC JohnFogarty FIRST Tech Challenge 2 25-11-2009 19:13
[FTC]: Programming Clarification [RobotC] basicxman FIRST Tech Challenge 3 11-02-2009 20:21
[FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob PackersFan FIRST Tech Challenge 11 26-01-2009 21:25
[FTC]: RobotC Template gdo FIRST Tech Challenge 14 10-11-2008 06:26
