Go to Post Oh geez your using math. I never touched the stuff myself.:o - Koko Ed [more]
Unread 21-02-2010, 05:46
sp33chy sp33chy is offline
FRC #3332
sp33chy is an unknown quantity at this point
Servos not working
Yeah. As a last minute thing I am adding moving camera view. However the servo motor isn't working. Neither of the ones that I opened today work so I don't think it's hardware related. So I start off by making a Servo...
Servo beatrice = new Servo(4,10);
double beatricex; //double for angle
Digital module is in slot 4, with servo attached to PWM slot 10.
Then during teleop's loop, I have this:
if (rightjs.getRawButton(4)){
beatricex--;
if (rightjs.getRawButton(5)){
beatricex++;
beatrice.setAngle(beatricex);
Pressing the buttons does nothing. I have tried several variations, such as setting it with a constant in the code, using set instead of setAngle, and using an axis on the joystick. Nothing works. I'm thinking something stupid is being done by me and I'm just too blind and sleep-deprived to see it.
Unread 21-02-2010, 05:55
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Servos not working
Is the 6 volt power jumper installed on output 10? Without it, the servo has no power...
Unread 21-02-2010, 06:57
FRC #3332
Sorry for my noobiness, but I never dealt with getting 6v power out of the board and I'm the only person on my team working on this part. What exactly do I need to do/what is the jumper and how do I attach it?
I'm assuming it's the two pins next to the PWM so I will try that I guess.
Unread 21-02-2010, 13:37
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
yep, grab some jumpers off of a dead jaguar, they fit perfectly
Servos not moving Marlfox Electrical 2 09-02-2009 18:24
Working with spikes and servos in labview EROCK Technical Discussion 2 07-01-2009 11:38
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
CMUCam Servos not Responding on Robot krigby Programming 7 20-01-2006 23:19
Servos not getting right voltage sheyna Programming 2 17-01-2006 21:57
