Go to Post GP is a much longer-term investment, yet offers surprisingly high returns. Just like 401(k) plans, the important thing is to keep making contributions even when it seems there's no reward for it. - ayeckley [more]
Unread 21-02-2010, 08:54
Re: OTA Server Error
The safe mode toggle is not like safety goggles for the cRIO. It means that the cRIO will only load a small number of drivers. You do not want to have the safe mode dip on unless you are having problems with a corrupted image and want to flash or debug it.
Read the cRIO documentation if you want a more complete explanation of what the dips do.
Greg McKaskle
Unread 21-02-2010, 10:43
1168Programmer 1168Programmer is offline
Head Programmer/CEO
FRC #1168
Team Role: Student
1168Programmer is an unknown quantity at this point
Greg McKaskle
Ah, thanks. I did not realize that.
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
