Go to Post With computers, every once in a while you see something that makes you think "I could have done this, why didn't I think of it? It would have made my life so much easier." Now is one of those times. - Nadav Zingerman [more]
Unread 21-02-2010, 08:50
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
Plaction and Omni wheels
Ok, so we got our bot up and running last night. Our robot had been unable to turn, but we have omnis in the four corners of a six wheel drive. Watching this thing spin in high gear was pretty crazy. Unfortunately while we were stress testing , one of the treads came off our plaction wheel. We assumed Andymark used a epoxy of sorts to adhere the tread to the wheel, but in reality the tread is only held on by three weak staples. How are we supposed to reattach it? Andymark suggests rivets, but I wonder if that is legal due to rules about metal and the floor. Could we use regular epoxy to adhere the tread?
My other question is why did this happen. Is this a common occurrence? I assume it is because the omni's radius is about .125 smaller making them in effect travel slower at the same RPM. Could this have been that cause of the problem? Do we need to gear the omni wheels so that they are going closer to the same speed? And more importantly, why aren't 8 in wheels 8 in?
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 21-02-2010, 08:57
Chris is me's Avatar
AKA: Pinecone
Re: Plaction and Omni wheels
The product page for the wheel says that the tread is only held on by the pressure of the wheels clamped together, this lets you swap out tread easily. For rough and wedgetop, installing rivets prevents any slipping and dragging issues. Once you drill the hole and rivet the ends, the rivet sits under the rest of the tread enough that it doesn't really contact the ground. Teams have riveted tread onto wheels for years with no issues, so you should be good. I don't know how strong your epoxy is or how well it would adhere to tread / wheels.
The tread probably failed due to the stress of wheels pulling in opposite directions. Slightly slower omnis probably had little to do with it, I wouldn't fret too much over gearing for 1/4".
Unread 21-02-2010, 09:01
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Using rivets to attach tread is a tried-and-true method of attachments in FIRST.
Put a couple on the ends and you will be OK. You could used a little epoxy on the ends but that makes replacing treads harder.
Unread 21-02-2010, 09:02
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Plaction and Omni wheels
In the past, we have used a combination of "Shoe Goop" and safety wire to hold our tread material to our wheel surface. As long as you place the safety wire in the low spots of the tread, it will not contact the carpet, and should be legal. We do this in eight equally spaced locations around the perimeter, paying special attention to where the ends of the belting meet. Drill small holes through the rim and twist the safety wire together within the wheel rim.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 21-02-2010, 09:16
Edoc'sil's Avatar
FRC #2531
Thank you for the speedy response. We will do the quick and easy glue and wire to ship with and bring riveted wheels to our competition.
Unread 21-02-2010, 09:41
IndySam's Avatar
With the withholding allowance you don't have to ship them at all.
Unread 21-02-2010, 09:46
Edoc'sil's Avatar
FRC #2531
*ship and practice
Unread 21-02-2010, 12:20
KC1AJT's Avatar
KC1AJT KC1AJT is offline
Head Mentor
AKA: Patrick
FRC #6617 (Bellinghan High School Black Hawks Robotics Club)
KC1AJT is an unknown quantity at this point
here's a picture of our bot:
it is a six wheel drive with the omnis in front and 4 plactons in the back on a pivoting drivetrain we have had no issues with the tread (just normal wear) i would recommend putting your plactons at the back so that you dont create that twisting shear between the carpet and wheel
Mentor - Team 6617
_____________________________________________
Student Years - Team 61
2011 Boston Regional
2011 BAE Systems/Granite State Regional
2010 Northeast Utilities FIRST Connecticut Regional Finalist
2010 Boston Regional
2009 Archimedes Division
2009 Connecticut Regional
2009 Boston Regional Regional Winner
AndyMark Plaction Wheels Diserasta Technical Discussion 1 17-01-2010 22:20
Plaction Wheels : 250 Spacers/Review Ice Berg General Forum 2 17-01-2010 11:26
Omni Wheels and Carpeted Playing Field? jimmythetulip22 Technical Discussion 16 25-01-2008 14:24
Israeli teams and Omni wheels 3dude_2231 Technical Discussion 9 13-11-2007 02:04
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
