Go to Post "Heres a band aid to keep your blood off the robot." - littleelectron [more]
Unread 19-02-2010, 20:50
pSYeNCe's Avatar
pSYeNCe pSYeNCe is offline
Programaster
AKA: James
FRC #2010 (Lightning Bots)
pSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to behold
Re: SOFTWARE PROBLEM!!!! PLEASE HELP!!!
Oops, I misspoke. We don't have a while loop in the teleop code so I really don't know what's causing this. I've looked at the DS and we get a "Watchdog not fed" for a splitsecond every half second, so it must be something timed.
Unread 20-02-2010, 09:39
It sounds like there is something in teleop not allowing it to finish on time. This could be a delay, time consuming computation, lots of I/O, or a combination.
Greg McKaskle
Unread 20-02-2010, 10:19
pSYeNCe,
Greg explains one possible way to monitor your Teleop throughput margin in this post:
http://www.chiefdelphi.com/forums/sh...d.php?p=924284
Unread 20-02-2010, 20:14
pSYeNCe's Avatar
Programaster
AKA: James
Absolutely. You can read the millisecond clock simply by dropping the Tick Count block. It is used for timing the Vision code and elsewhere in the framework. You can read it at the beginning and end of Teleop, or you can read it each entry, etc. You can also make use of the Match Info.Elapsed Seconds which has millisecond resolution. It comes from the same clock, and you can use it at the beginning of Teleop to identify a missed packet. I've made notes about how each of the choices listed would impact the robot if they were the chosen method.
That's from the link you recommended, and I just don't understand what he means on how to identify the missed packet.
As a side note, we're going to reload the original code (after all the batteries recharge, which somehow all became dead at the same time ).
Edit: We're also going to try disabling Vision to see if that's causing the problem.
Unread 20-02-2010, 23:13
Read the clock at the beginning of teleop and compare it to the clock value from the previous iteration of teleop. If the difference is 40 ms (or 60ms or 80ms etc) instead of 20ms then you've run out of realtime and missed a packet (or 2 or 3 etc).
Or, read the clock at the beginning and end of teleop and look at the difference to see what your throughput margin (or overrun) is.
Unread 21-02-2010, 02:06
theanabanana theanabanana is offline
FRC #0093
theanabanana is an unknown quantity at this point
We figured out how to optimize it by changing the image taken to grayscale (U8). This reduced the cycle time for the while loop in the Robot Main from 300 to about 180ms. This is better, but still not very reasonable. 100ms at least would be a better goal.
It also significantly lowered the cycle time of the while loop when we changed the image resolution to 160x120. However, making the images this size is not beneficial at all because the ellipses are hard to read at that size.
Sooo while our robot's electrical mounting is taking place (therefore I cannot test/debug the cycle time), I'm studying the Vision VI in the bottom Flat Sequence Structure. There is a comment in inside its Camera: Update Status VI, written by the original programmers of the default code (not to be confused with the standard .lvlib library code) . It says:
This subVI is reentrant so that it will work correctly if used in multpile locations. You may want to change the VI Property to disable reentrancy if debugging.
I don't believe the Camera: Update Status VI needs to be implemented anywhere else in the code really.
So, I'm planning on taking the shift register out and feed the "Enable Vision" global into the simple case structures inside the original shift register. It's one less step to go through, and could reduce the time spent in each cycle. I'm not sure if it will be a significant amount of time, but we can still shave the cycle time down in as many places as possible to reach our less-than-ideal but realistic goal of 100ms.
Ana
Unread 21-02-2010, 02:42
FRC #0093
So the changes I said I was going to do: I implemented them and it didn't lower the cycle time at all.
I thought I'd show you how I got the waveform chart on my front panel of my Robot Main.vi. Well: rt-click, Graphs, waveform graph. Then go to the block diagram and implement this in the main while loop that includes your robot mode and whatnot and implement the code in the jpeg I've attached.
Still working on it,
Ana
Unread 21-02-2010, 08:52
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Unread 02-19-2010, 12:37 PM
Mark McLeod's Avatar [Mark McLeod]
Itinerant Programmer
If you care to zip up the entire project and post it we can help diagnose code delays. Time is getting short...
Any messages on the Driver station Diagnostic screen?
Any lengthy "Watchdog not Feed" statuses showing up in the lower left corner box?
Any oddly behaving status lights?
Does the RSL have a consistent long-on/short-off blink sequence or is it disrupted?
We keep getting "watchdog not feed" messege cntinousaly when we enable the robot. Also out switches on the kicker, are in the wrong place in the software... only in the dashboard i dont know why. AND IT IS VEEEEEEEEEERY laggy. please help
Unread 21-02-2010, 09:39
You have some actions, probably in Teleop, that are taking way too long.
Most likely While loops.
We'd have to see the code to help much more.
Unread 21-02-2010, 10:43
I debugged a lagged robot at a scrimmage yesterday. We didn't get to the bottom of all the problems, but here is one easy thing to look for. The Watchdog function to delay and feed had a 1000 wired to it. The student read it as delaying 1000 ms. But of course the units to that function aren't ms, but s. So that explained why their solenoid didn't seem to run more than once.
Anyway, now is a great time of the season to do code reviews. Go screen by screen explaining the code to another person. Add comments to the code where you find yourself guessing, guessing again, and correcting yourself because you cannot even explain your own code without comments. Add comments when you find that what you are saying verbally is way more than what is in the code and you are explaining how this piece on another screen does something that this code depends on, etc.
Finally, if you are the other person with the code being read to them, ask lots of questions such as what units is that parameter or output in? How does that value get initialized? Let's go look at the configuration of that I/O and see if it matches how you are reading it. If what they said doesn't seem to match the logic or math in the code, ask them to explain it again with less hand-waving.
It is surprising how many issues you will find just by being forced to proofread the code for what is there versus what you meant to put there. With some practice, you'll find that you hardly need the other person there. You can learn to read the code with new eyes as if explaining it to another person, and you'll find yourself asking some of those same questions and fixing bugs without having to go through hours of robot observation.
Greg McKaskle
Unread 21-02-2010, 12:41
Andy Bradley Andy Bradley is offline
FRC #0233
Andy Bradley is an unknown quantity at this point
We are having lag problems too, and I think its related to the latest set of updates. In our crio log file (while connected to the robot, select the diagnostics tab on the driver station screen, and then click the "View Log File..." button), the robot is recording up to 12 error messages per second associated with the cypress module (which we aren't using at all). This particular problem is being discussed in this thread, http://www.chiefdelphi.com/forums/sh...272#post925272
but there is no solution found yet.
Unread 21-02-2010, 14:06
pSYeNCe's Avatar
Programaster
AKA: James
Good news, I disabled vision and the lag stopped entirely. I looked through the code and on the front panel of Begin.vi, the res is 160x120, but it is set to 320x240 on Robot Main.vi. I wonder if that was causing the problem (trying to convert the res slows it down or something). Unfortunately I won't have any time to test more, since we have to focus on more core aspects in these last few hours :O.
Last edited by pSYeNCe : 21-02-2010 at 14:13. Reason: I didn't complete my thought -_-
Unread 21-02-2010, 15:13
Anytime you see values on a subVI panel such as vision, those are the defaults. In this case, you'll see that the resolution is being set to the Main VI's values via a global, and perhaps via a parameter.
There was no conversion going on, but the camera does by default use the medium image size. You can leave vision on and use the smaller image size, or you may want to play with the image compression. I believe that if you set it to around 20%, the performance will change.
Greg McKaskle
Unread 21-02-2010, 16:07
pSYeNCe's Avatar
Programaster
AKA: James
Greg McKaskle
Okay, we'll have to play around with that. Thanks to everyone for all the help!
Please help; HUGE mplab problem brennerator Programming 5 09-01-2007 01:25
IFI_Loader Problem, please help. winners Programming 9 18-01-2006 17:54
BIG Problem, please help me!! Srkasner FIRST Tech Challenge 2 11-01-2006 12:45
gearing problem. Help please! camsrobotics Motors 9 22-01-2005 20:45
BIG PNUEMATIC PROBLEM NEED HELP PLEASE!!!! archiver 2001 1 24-06-2002 00:30
