Go to Post Yellow bananas are the new red herrings. - artdutra04 [more]
Unread 02-21-2010, 12:36 PM
/*P4bl0*/'s Avatar
/*P4bl0*/ /*P4bl0*/ is offline
FRC #0231
/*P4bl0*/ can only hope to improve
Question switching the x & y on joy stick
hello i been trying to get the holonomicDrive working right for some time now i just want to get the joy stick to switch its x & y input and i cant get in to the joystick source code and change it plz some one help me
Unread 02-21-2010, 12:50 PM
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: switching the x & y on joy stick
Can't you just reverse how you are implementing the axes in your code?
For example, if you are setting variable "velocity" to the y-axis, just set it to the x axis instead.
Alternatively, you could create new variables such as "newX" and set the actual y-axis to newX.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 02-21-2010, 01:18 PM
/*P4bl0*/'s Avatar
FRC #0231
ok i may be saying some thing wrong or i dont get what your saying (this is my first year mostly alone on getting this to work) ok i have this
m_robotDrive.holonomicDrive(m_rightStick.getMagnit ude(), m_rightStick.getDirectionDegrees(), m_leftStick.getX());
in the code and its the only places i have the joystick input i dont want to change the left stick at all i tried swiching m_rightStick.getMagnitude() and m_rightStick.getDirectionDegrees() but it goes hay wire and i did not change anything else.
were using mecanum wheels and i have them on inputs of
front
4 2
1 3
back
some how it works but i just have the x and y mest up ..
i might be giving random info and not making any scenes
Unread 02-21-2010, 01:45 PM
AKA: Bryan
I haven't looked at the default holonomic code this year, but from that code it looks as though the holonomic drive function is expecting you to use a 3-axis joystick.
m_rightStick.getMagnitude() would be the y-direction
m_rightStick.getDirectionDegrees() would be the "twist" of the joystick
m_leftStick.getX() would, of course, be the x direction.
Are you using a 3-joystick set up? If not, then you will need to use a different holonomic drive method. If so, then all you should have to do is switch getMagnitute() and getX(). Thus the line would read-
m_robotDrive.holonomicDrive(m_leftStick.getX(), m_rightStick.getDirectionDegrees(), m_rightStick.getMagnitude());
Unread 02-21-2010, 01:58 PM
/*P4bl0*/'s Avatar
FRC #0231
no were using 2 logtech atk 3 joysticks witch you cant twist the joystick and changing
to
m_rightStick.getX()
just disable are y axis from the right joy stick
Unread 02-21-2010, 01:59 PM
/*P4bl0*/'s Avatar
FRC #0231
sorry i read the code wrong i did not see you switch something else
Unread 02-21-2010, 02:20 PM
AKA: Bryan
Well since you do not have a 3-axis joystick you need to send something other than m_rightStick.getDirectionDegrees().
And wow, sorry, I just realized that you already have two different joysticks there. My bad! In any case, they still wont be able to give you a degree measurement.
Is the second parameter just a float (does getDirectionDegrees() return an int from 0 to 360 or a float from -1 to 1)? If so, I would replace m_rightStick.getDirectionDegrees() with m_rightStick.getX()
Joy stick function description Bruceb Technical Discussion 4 02-13-2009 02:40 PM
Acceleration limiter on the joy stick Bruceb Technical Discussion 5 01-21-2009 06:53 PM
Joy stick variables. Joshamuffin Programming 2 04-16-2008 05:49 PM
Joy stick Sairamluap Control System 4 02-01-2008 04:04 PM
Joy Stick CAD rcubes85 Inventor 0 01-26-2005 09:37 AM
