Go to Post I'd say it is somewhat addicting. But I think that is a good thing. It proves that knowledge can be addicting. How cool is that? Now, if we could just get everyone addicted to knowledge, just think of what we can accomplish.:D - Molten [more]
Unread 21-02-2010, 13:51
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Watchdog Problem
We are hyaving a problem with our watchdog. It times out every .5 - 2 seconds. The longer we run the robot the more time outs we have. We have tried disabling the watchdog and it still times out. Me and my dad believe that it is the System Watchdog. We have disabled the camera image on the dashboard and still no luck. Any one know how to fix this?
Unread 21-02-2010, 14:28
kgzak's Avatar
AKA: Kris
Re: Watchdog Problem
Also every once in a while our code will just get stuck, like it's in a loop. But we only have one loop in our main.
Unread 21-02-2010, 14:37
JoeyTNT280's Avatar
JoeyTNT280 JoeyTNT280 is offline
Scouting
AKA: Joey
FRC #0280 (TnT)
JoeyTNT280 is an unknown quantity at this point
Send a message via AIM to JoeyTNT280
Also having issues with Watchdog time out errors. It does it in short spurts but turns our compressor off every time.
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 21-02-2010, 14:47
Did you install the Driver Station update 1.1?
Unread 21-02-2010, 14:50
JoeyTNT280's Avatar
Scouting
AKA: Joey
FRC #0280 (TnT)
280 did. It only started doing this 5 minutes ago or so (probably longer but yeah) and was working just fine before.
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 21-02-2010, 15:06
kgzak's Avatar
AKA: Kris
I am pretty sure we installed the Driverstation update. under DS version in the diagnostics it says 2010.01.06.00 Is this correct?
Unread 21-02-2010, 15:19
That's the first update (1.0). You need to install version 1.1, which was released about a week ago and fixed several system watchdog issues.
Unread 21-02-2010, 16:09
JoeyTNT280's Avatar
Scouting
AKA: Joey
FRC #0280 (TnT)
I checked my DS for a third time and its updated to 1.1
Were getting
Watchdog Experation: System 2, User 7
Watchdog Experation: System 2, User 8
Watchdog Experation: System 2, User 9
Watchdog Experation: System 3, User 9
Watchdog Experation: System 3, User 10
Watchdog Experation: System 4, User 10
Watchdog Experation: System 4, User 11
Everytime we get one of those errors our system shuts down for a spit second or so.
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 21-02-2010, 18:55
The current printout in the Diagnostics doesn't identify the reason, so legitimate disabling of the robot shows up as a watchdog.
The user watchdogs are due to code not feeding the watchdog. System watchdogs are either due to a disable or due to a timing glitch caused by the DS. The second ones should be pretty rare, but we are still tracking down some reasons they can occur.
Anyway, look for the reasons that your code is getting hung up. Put timing code in each and every loop and in the teleop subVI. Watch those either on your panels or on your dashboard to determine which loop is late.
Greg McKaskle
Unread 21-02-2010, 19:54
kgzak's Avatar
AKA: Kris
we are still getting Watchdog Timeouts even when we disable the watchdog. There aren't as many but we still get them.
Unread 21-02-2010, 20:37
Lumit Lumit is offline
FRC #2521
Lumit is an unknown quantity at this point
We're having the same issue as well.
http://www.chiefdelphi.com/forums/sh...ad.php?t=83116
Problem with System Watchdog JSonntag NI LabVIEW 14 20-02-2010 11:31
Watchdog Problem daniel_3158 Programming 3 12-02-2010 15:22
example project Autonomous mode Watchdog problem qpang NI LabVIEW 0 08-02-2010 16:17
Watchdog!?!?!?! NC GEARS General Forum 38 23-01-2010 08:52
Watchdog darty NI LabVIEW 8 16-02-2009 09:11
