Re: Watchdog Problem
280 did. It only started doing this 5 minutes ago or so (probably longer but yeah) and was working just fine before.
I am pretty sure we installed the Driverstation update. under DS version in the diagnostics it says 2010.01.06.00 Is this correct?
That's the first update (1.0). You need to install version 1.1, which was released about a week ago and fixed several system watchdog issues.
I checked my DS for a third time and its updated to 1.1
Were getting Watchdog Experation: System 2, User 7 Watchdog Experation: System 2, User 8 Watchdog Experation: System 2, User 9 Watchdog Experation: System 3, User 9 Watchdog Experation: System 3, User 10 Watchdog Experation: System 4, User 10 Watchdog Experation: System 4, User 11 Everytime we get one of those errors our system shuts down for a spit second or so. Last edited by JoeyTNT280 : 21-02-2010 at 16:14. |
The current printout in the Diagnostics doesn't identify the reason, so legitimate disabling of the robot shows up as a watchdog.
The user watchdogs are due to code not feeding the watchdog. System watchdogs are either due to a disable or due to a timing glitch caused by the DS. The second ones should be pretty rare, but we are still tracking down some reasons they can occur. Anyway, look for the reasons that your code is getting hung up. Put timing code in each and every loop and in the teleop subVI. Watch those either on your panels or on your dashboard to determine which loop is late. Greg McKaskle |
we are still getting Watchdog Timeouts even when we disable the watchdog. There aren't as many but we still get them.
#7
We're having the same issue as well.
http://www.chiefdelphi.com/forums/sh...ad.php?t=83116 |
| Problem with System Watchdog | JSonntag | NI LabVIEW | 14 | 20-02-2010 11:31 |
| Watchdog Problem | daniel_3158 | Programming | 3 | 12-02-2010 15:22 |
| example project Autonomous mode Watchdog problem | qpang | NI LabVIEW | 0 | 08-02-2010 16:17 |
| Watchdog!?!?!?! | NC GEARS | General Forum | 38 | 23-01-2010 08:52 |
| Watchdog | darty | NI LabVIEW | 8 | 16-02-2009 09:11 |
