Go to Post Maybe FIRST could get a sponsorship from Ikea, and we all could get flat-packed field parts with pictoral assembly instructions. And then all the parts could have funny names. - sanddrag [more]
Unread 21-02-2010, 15:31
Re: bridge ip?
See section 2.10 of the control system manual.
Unread 21-02-2010, 15:49
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: bridge ip?
but what are the settings from last year that would be on there since the default no longer works
IP:10.9.32.1?
Subnet mask:155.0.0.0?
Default gateway:10.9.32.4?
Unread 22-02-2010, 00:04
Re: bridge ip?
You'll probably have better results if you reset everything to their defaults and then follow the directions in the manual.
Unread 22-02-2010, 00:13
Phreadumb's Avatar
Phreadumb Phreadumb is offline
FRC 2188 Alumnus
AKA: Dakotah Jones
Phreadumb has a spectacular aura aboutPhreadumb has a spectacular aura about
Re: bridge ip?
More specifically, the 2010 FRC Controls Manual is what you want to look in.
Before starting, reset your bridge, hold button until amber light comes on and returns to green!
the default IP is 192.168.1.250.
I will be trekking into territories where FIRST teams do not exist, perhaps I should start one? Oh, but that's a lot of work.
Unread 22-02-2010, 15:48
AKA: Jon
Question Re: bridge ip?
Does setting it to get ip adress automaticly mean DHCP?
Bridge Designer Cyberguy34000 Chit-Chat 4 13-08-2005 21:07
Bridge problems? archiver 2001 8 24-06-2002 03:22
Buildable Bridge? archiver 2001 0 24-06-2002 01:18
bridge specs archiver 2001 2 23-06-2002 22:52
???Bridge??? archiver 2001 3 23-06-2002 22:35
