Go to Post We started FIRST to achieve a common goal and not only will we leave with more knowledge and wisdom, we will leave as friends and thats what really counts if you ask me. :cool: - Hick18 [more]
Unread 21-02-2010, 15:36
Phreadumb's Avatar
Phreadumb Phreadumb is offline
FRC 2188 Alumnus
AKA: Dakotah Jones
Phreadumb has a spectacular aura aboutPhreadumb has a spectacular aura about
Re: Inspection Checklist posted!
Hey, I was just checking out the inspection sheet, and I noticed in the electrical catagory it said "Motors - 5 CIM, 2 Denso Left, 2 Denso Right, 2 Fisher Price, and 2 Mabuchi. <R52. A,D,E>" So I was wondering if I needed to uses 2 left and 2 right left denso motors, and not somthing like 4 left as intended? I looked at A, D, and E and what I'm doing seems to be in compliance.
I will be trekking into territories where FIRST teams do not exist, perhaps I should start one? Oh, but that's a lot of work.
Unread 21-02-2010, 15:56
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Did you receive four left-side Denso window motors in your Kit of Parts? You should have received 2 lefts and 2 rights and are limited to using 2 of each per rules <R52> and <R53>.
What do you mean by using "4 left as intended"?
Russ
Unread 21-02-2010, 16:33
neurotrek neurotrek is offline
FRC #2493
neurotrek is an unknown quantity at this point
In the same area is the new Rev J of the robot rules Section 8. Please be aware that changes to the robot rules will be enforced at events. Inspectors will use the latest version of the rules and the inspection checklist at each event. Read and compete.
Hello,
Does this mean that all the updates have been included in the robot rules?
Unread 21-02-2010, 16:47
Neurotrek,
Your question is too vague. Teams have a number of resources that need to be periodically checked in order to stay up-to-date. It can be daunting but at least one person from every team should keep up with the following docs and forums - Section 8, Team Updates, FIRST's Q&A forum, Bill's Blog and the inspection checklist.
Section 8 is THE guiding document when it comes to robot inspection. There are, however, some rules interpretations and clarifications that are not rolled into Section 8 and are instead posted as responses in the Q&A forum or as reminders in Team Updates. I try to keep the inspection checklist and inspector training manual synchronized with the various sources of information.
Russ
Unread 21-02-2010, 16:55
Every time a Team Update comes out, the sections that are altered in the Update are issued as Section X Rev Y. Q&A answers are not automatically included--typically, the entire Q&A is published at some point between the end of build season and the Week 1 events. You'll want to grab that when it does come out.
If you have something like Section 8 Rev B, you really need to update which revision you have.
Unread 21-02-2010, 16:59
FRC #2493
Originally Posted by Russ Beavis View Post
Neurotrek,
Russ
Russ,
Perhaps I was a bit vague. Anyways, your reply pretty much answered my question. I checked through all the rules, updates and what-not to clarify.
Thanks.
Robot Size- R11 vs. Inspection Checklist Toby314 Rules/Strategy 4 07-01-2008 10:09
Robot Inspection Checklist ChuckDickerson Technical Discussion 2 16-02-2006 21:30
Update 11 is posted, with Inspection Checklist Tristan Lall General Forum 2 15-02-2005 21:34
Inspection Checklist Draft Available Yan Wang General Forum 1 26-02-2004 20:14
Have you seen the Inspection Checklist? Matthew_H General Forum 20 23-02-2003 19:55
