Go to Post Those poor suckers on the West coast get three hours LESS sleep than we do afterward. Anyone else glad to see that crate go every year, regardless of what's in it? - Rich Kressly [more]
  #106   Spotlight this post!
Unread 27-03-2009, 19:47
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: how many people have had failing jaguars
We had one die for no obvious reason today. Worked in the pits, then once we got on the field, nothing. No light, good power, good pwm. Luckily, we had a spare already mounted and wired to the distribution block.
  #107   Spotlight this post!
Unread 27-03-2009, 22:52
Jared Russell's Avatar
Taking a year (mostly) off
2 Regionals, 27 regular matches, and over a dozen practice matches and all three of our Jags are still running strong.
  #108   Spotlight this post!
Unread 27-03-2009, 23:51
Racer26 Racer26 is offline
854 toasted one on the practice field minutes before a match 1075 was set to play against them in Waterloo... I helped them swap it. I wanted to beat them on the field, not off it. (We did... 64-30)
  #109   Spotlight this post!
Unread 28-03-2009, 00:36
Liu_yiang Liu_yiang is offline
AKA: Ian Pai
FRC #1245 (Shazbots)
Team Role: Electrical
Liu_yiang is an unknown quantity at this point
Ours died rather early in the build season. A stroke of luck, considering what I've been hearing and reading from other teams.
  #110   Spotlight this post!
Unread 28-03-2009, 11:52
Tazlikesrobots's Avatar
Tazlikesrobots Tazlikesrobots is offline
Jack of all trades...Master of none
AKA: Robert
FRC #1745 (P-51 Mustangs)
Tazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud of
Send a message via Yahoo to Tazlikesrobots
We had one fail during a match at the Dallas Regional. Thankfully our design incorporates a redunant system and we were able to continue in the match with one dead speed controller!
It is all mind over matter....If you don't mind, it does not matter.
_________________
2006 Woodie Flowers Award Recipient - Lone Star Regional
2006 Rookie All-Star - Lone Star Regional
2007 Lone Star Regional Champions
2008 Quarter-finalist - Lone Star Regional
2009 Chairman's Award & Website Award - Dallas Regional
2009 Quarter-finalist - Dallas Regional
2010 - Xerox Creativity Award & Semi-finalist - Dallas Regional
  #111   Spotlight this post!
Unread 28-03-2009, 23:49
Jablonski@1250's Avatar
Jablonski@1250 Jablonski@1250 is offline
AKA: Greg Jablonski
FRC #1250 (Gatorbots)
Jablonski@1250 has a spectacular aura aboutJablonski@1250 has a spectacular aura about
Re: just wondering
Ours failed at Cleveland- we we pulling x amount of current through them and for some reason they would shut down. The Luminary Microsystems rep couldn't offer an explanation why. This happened twice, so we pulled them and replaced them with victors and have not had a issue since.
  #112   Spotlight this post!
Unread 30-03-2009, 17:56
Phil Ross's Avatar
Phil Ross Phil Ross is offline
Constantly Inspired
FRC #1712 (Dawgma)
Phil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to behold
Send a message via AIM to Phil Ross
Talking Re: how many people have had failing jaguars
From what I understand a lot of people have been blowing up Jags this year. One cause that I heard was common was that when you sent either a 1 or -1 value from the joystick to the motor the jags would blow up. Although this was an easy problem to fix (just set the values to .99 and -.99) our team opted out of using the jags this year because this was all unknown and we figured "why not use the extra victors we have lying around while we still can."
Hope I could help
FIRST Americorps VISTA, Philadelphia
DAWGMA TEAM 1712: Alumni (2006-2009)
  #113   Spotlight this post!
Unread 21-02-2010, 16:24
voteforandy1 voteforandy1 is offline
FRC #3131
voteforandy1 is an unknown quantity at this point
Yeah, victors are smaller, and less breakable. But jags are smoother and offer so many more options.
  #114   Spotlight this post!
Unread 21-02-2010, 18:33
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
We blew out a jaguar after 5 tries using our winch to lift ourselves up.
Swapped it with a victor and no problems since then.
  #115   Spotlight this post!
Unread 21-02-2010, 18:37
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Do you have any explaination why, or is this just imperical data.
___________________
- Tennyson, Ulysses
  #116   Spotlight this post!
Unread 21-02-2010, 18:50
waialua359's Avatar
AKA: Glenn
We dont have any explanations other than the fact that after repeated tries, no problem since, all else the same.
  #117   Spotlight this post!
Unread 23-02-2010, 20:59
RevusHarkings RevusHarkings is offline
FRC #3396
RevusHarkings is an unknown quantity at this point
We just blew one of our Jags about an hour ago. It started smoking, a part melted inside, and now it only drives in one direction. We'd rather not request a new one from TI, so if anyone from the GTA has a spare, we'd greatly appreciate it if you sent it our way.
  #118   Spotlight this post!
Unread 24-02-2010, 20:55
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Why not request one? It is simple, they ship them quickly, and want the bad one back to analyze. And no cost to your team!
Frankly, I was 'down on Jags' until I sent 2 back, and experienced their tech support.
  #119   Spotlight this post!
Unread 24-02-2010, 21:46
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Revus - I'm not sure why you wouldn't want to send it back. They'll replace it for free with no hassle (unless you did something insane like drilled a hole through it).
  #120   Spotlight this post!
Unread 25-02-2010, 10:14
1075 smoked 3 Jags on ship day (Black Jags, too). Can't see any particular reason why. We're working on getting them replaced.
How many teams had router problems? darkember Technical Discussion 8 31-01-2009 21:22
How many people like bumpers? diesel Rules/Strategy 53 24-01-2008 15:30
How many people like bumbers? diesel Rules/Strategy 3 18-01-2008 17:34
How many people get on CD at school... Ashley Christine Chit-Chat 37 21-06-2005 13:14
how many of u actually used the stacker if u had one? HolyMasamune General Forum 21 14-04-2003 13:12
