Go to Post Remember, only YOU can set a good examples for rookies to search CD first before asking questions or responding!! - Foster [more]
Unread 21-02-2010, 17:06
Re: Question about things that MUST be on the robot w/o compressor
<R76-D> If the compressor is not included on the ROBOT (under the provisions of Rule <R75>), the regulator may be located on-board or off-board, provided all other pneumatic rules are satisfied. Note that if the regulator is kept off-board the ROBOT with the compressor, then only low-pressure (60psi or less) “working” air can be stored on the ROBOT.
<R77> The relief valve must be attached directly to the compressor. If the relief valve is already set to 125psi, teams are not allowed to adjust it. If the relief valve is not set to 125psi, teams are required to adjust to release air at 125psi. The valve may or may not have been calibrated prior to shipping.
<R78> The Nason pressure switch must be connected to the high-pressure side of the pneumatic circuit (i.e. prior to the pressure regulator) to sense the “stored” pressure of the circuit. The two wires from the pressure switch must be connected directly to a digital input and ground port on the Digital Sidecar, and the cRIO-FRC must be programmed to sense the state of the switch and operate the relay module that powers the compressor to prevent over-pressuring the system.
<R79> The Parker pressure vent plug valve must be connected to the pneumatic circuit such that, when manually operated, it will vent to the atmosphere to relieve all stored pressure. The valve must be placed on the ROBOT so that it is visible and easily accessible. If the compressor is not used on the ROBOT, then an additional vent valve must be obtained and connected to the high-pressure portion of the pneumatic circuit off board the ROBOT with the compressor (see Rule <R74>).
Also, under <R75>, off-board compressors must be controlled by the robot.
pic: Oh The Places We Go And The Things That We See! JaneYoung Extra Discussion 10 10-07-2010 19:41
General question about the robot controller itsme Technical Discussion 6 14-01-2007 15:33
Things that new members need to know about electronics Karma Electrical 10 20-11-2006 08:35
A question about taking the robot.... Natsume General Forum 3 26-02-2003 19:31
Aggravating things about the competition itself.. archiver 2001 6 24-06-2002 02:26
