Go to Post An explanation of the reasoning behind design decisions will almost always result in a more thorough understanding of the solution than analysis alone can obtain. - Travis Covington [more]
Unread 21-02-2010, 16:28
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Question Norgren regulator question
Up until now, our air has been just fine. Now our regulator started leaking, and now I think it was just another bad connection. But now that I realize it, our regulator is rated at 50PSIG Max output (part no. R07-100-RNEA), up until today we had working fine at 60 PSI.
Any facts out there?
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 21-02-2010, 17:25
RKElectricalman's Avatar
RKElectricalman RKElectricalman is offline
Meezy the Mentor
AKA: Rameez
FRC #0384 (Sparky 384)
RKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really nice
Send a message via AIM to RKElectricalman
Re: Norgren regulator question
On the BACK of the valve there should be a set screw in place that you should start at first. Put teflon tape on the set screw and re-tighten it and make sure there aren't any leaks in the system again. Also, don't forget to make sure the arrow at the bottom of the regulator is pointing in the direction of the solenoids.. It needs to flow TO the solenoids, not away from. We had that issue and it wouldn't let our tanks fill up further than 60PSI
ahhh Division Finalists!!
Does the Norgren Pressure Regulator show working pressure or stored pressure? Madison Pneumatics 7 14-02-2008 17:40
Voltage Regulator Robby Electrical 5 18-01-2005 07:50
12v regulator coreyjon Electrical 1 09-06-2004 22:08
pressure regulator blindguyinanorg Pneumatics 12 20-02-2004 08:54
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
