Go to Post There are so much more things to be worked on and are more beneficial to FIRST and FIRSTers than green dots by someone's name. - tiffany34990 [more]
Unread 02-21-2010, 02:33 PM
chris janney chris janney is offline
FRC #3266
chris janney is an unknown quantity at this point
Exclamation spike relay code urgent
ok hi all
ok i am a part of our mechanical team, and our programmer isnt here. we ship in two days and our spike relay isnt programmed. can someone please show me the nessacary coding for it. if it helps we are using java.
Unread 02-21-2010, 05:55 PM
Trevor_Decker's Avatar
Trevor_Decker Trevor_Decker is offline
AKA: Trevor Decker
FRC #3504 (Girls of Steel)
Trevor_Decker is an unknown quantity at this point
Re: spike relay code urgent
Place the flowing code where your joysticks are being declared
Relay spike = new Relay(4,1);
Then put the flowing in the method teleopPeriodic()
assumes that you want the spike to turn on if the triger is pressed on a joystick named m_leftStick
  if(m_leftStick.getRawButton(1)){
spike.set(Relay.Value.kForward);
else{
spike.set(Relay.Value.kOff);
- Trevor
Team 3504 - The Girls of Steel 2011 - Present
2012 Pittsburgh Regional Engineering Inspiration, and website awards
Team 1743 - The Short Circuits 2009 - 2011
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2010 Won Autodesk Animation Competition
2010,2011 Pittsburgh Team spirit award
spike relay problem? Maxpower57 Electrical 15 04-09-2012 07:18 PM
Spike relay code not working wywern209 Programming 9 02-05-2010 10:04 PM
Relay (Spike) elbuo Electrical 2 02-09-2009 08:36 PM
Spike Relay Input nwagers Electrical 3 07-16-2002 10:23 PM
