Go to Post Don't ever give up on your robot, especially this early in the season. That robot is what you make of it. If you give it your all, something good is bound to come your way. - Amanda Morrison [more]
Unread 21-02-2010, 18:26
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Camera trouble
We set the camera in the robot today, and attempting to use the camera causes severe issues with the robot. After mounting and connecting, we connected the camera to a computer, ran the setup tool and the camera worked just fine in the Vision Assistant. Once the same cable plugged into the cRIO, the entire system failed. The NetConsole displays an abundance of S_ECONNREFUSED errors (or something like that), the lights around the camera flash between red and green, no images are on the dashboard, and the CAN bus becomes intermittent. If the camera is not referenced in code, the red and green lights continue, no images are on the dashboard (as expected), but everything else becomes normal again. I don't have time to look for the solution but any help would be greatly appreciated
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 21-02-2010, 18:46
Re: Camera trouble
I believe the blinking read and green indicates that the reset button is being pressed or has been pressed.
Greg McKaskle
Unread 21-02-2010, 19:05
AKA: Ian Thompson
Re: Camera trouble
That might be it. Our mounting box is very tight to the camera so there i a good chance the button is hit. I'll put a hole in it tomorrow and see if that works
Error -1074396080 camera trouble Kahn! NI LabVIEW 1 16-02-2009 12:24
Trouble With Autonomous Camera Tracking whswrestler189 NI LabVIEW 5 21-01-2009 19:20
I'm having trouble with this camera stuff Ianuser Programming 5 13-02-2007 10:45
Camera servo trouble Demothesis Electrical 5 27-01-2007 17:15
Having trouble with your camera mount? Chriszuma Programming 7 01-02-2005 22:12
