Go to Post Mentors can always use mentoring. - JaneYoung [more]
Unread 21-02-2010, 14:46
Carter12s's Avatar
Carter12s Carter12s is offline
Team Cap
FRC #3374 (Robo-Broncs)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
Additional Joysticks
Hey with the increased complication of our robots axillary function we are finding it necessary to increase the control system. We are a rookie team and we don't have an additional KOP joystick. We do have several other USB control devices but i cannot seem to make the OpenJoystick.vi work with them. What i would most prefer is if i could use a keyboard to control the aux functions. Can i capture key hits on the classmate controller or attach a additional keyboard and use that? Are there any vi's to do this? Or does anyone else known of a better system?
Unread 21-02-2010, 14:54
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
dotbran is on a distinguished road
Re: Additional Joysticks
It's possible, but I'm not sure exactly how to do it. You will probably have to use an external USB controller.
Not by default. You may be able to find one on OpenG.
Unread 21-02-2010, 15:22
Lots of HID joystick type devices will work. You can use the buttons around the joystick(s). If a device shows up in the gamepad section of the control panel, I believe it will work pretty well with the DS.
Greg McKaskle
Unread 21-02-2010, 15:41
Carter12s's Avatar
Team Cap
I used a couple of USB game controllers and tried everything i could think of with them. They both showed up in the Joystick window of the setup tab and their name would change color when the buttons were pressed but no response was received in the code.
Unread 21-02-2010, 18:48
How are you checking the buttons in the code? Right click and show the entire cluster.
Greg McKaskle
Additional IR Sensors? MaddyW Technical Discussion 2 04-02-2008 14:24
Additional Parts ph@ntom Robotics Education and Curriculum 6 23-11-2004 23:52
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
Additional Joysticks/Modification Jordan A. Rules/Strategy 16 02-03-2003 21:15
additional materials Penn Robotics Off-Season Events 1 01-11-2001 23:25
