Go to Post I just think that if we are going to have rules intended to level the playing field, they shouldn't hurt teams that put the effort in to go the extra mile. - Dave Scheck [more]
Unread 21-02-2010, 18:55
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Code for Encoder isn't working
While we can probably understand your code, it will take us a long time if we have to try to figure out what's going wrong. Let us know what it's doing wrong/what it's not doing and we'll be able to help you better and more expediently.
One thing I've noticed initially, though, is that in the code pasted into your post, the wires going between the loops probably won't do what you want, as values will only be propagated along them once, after the source (top) loop finishes. This also means that the bottom loop won't run until the top loop has been stopped, but then since the value wired to the stop terminal on the bottom loop will already be true, the bottom loop will only run once.
--Ryan
FRC 766, 2015-, Mentor
encoder code for 18f8520 cau.denny General Forum 2 17-03-2009 12:51
Help! Autonomous isn't working... DotCom Programming 1 09-02-2007 21:09
Camera isn't working Idaman323 Programming 13 15-02-2006 23:18
PERL isn't working... Joe Ross CD Forum Support 1 19-06-2001 10:14
