Go to Post And yes. The Super Bowl is on, and I'm replying to a thread on Chief Delphi... - BobbyVanNess [more]
Unread 21-02-2010, 20:14
Patrick Levy Patrick Levy is offline
FRC #3202
Patrick Levy is an unknown quantity at this point
Charging Batteries
We are using the charger supplied with the kit of parts and have been charging on the 2 amp setting. Have other teams found that it is OK to charge these batteries faster than the 2 amp setting? Do you notice a decrease in battery performance or longevity?
Thanks,
Patrick Levy
Team 3202
Unread 21-02-2010, 20:16
ubermeister's Avatar
ubermeister ubermeister is offline
AKA: Eric VA
ubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the rough
Re: Charging Batteries
The old chargers (I think 07 and before) were fixed at 6 amps. We have always charge our batteries at 6 amps simply because we need the quick charging to keep our robot running. FIRST also says that battery chargers can be up to 6 amps. Can't say anything about performance differences, though.
Unread 21-02-2010, 21:07
The battery manufacturer recommends charging at no greater than 6 amps. Your supplied charger is capable of 6 amps at the maximum setting if you select it. Never charge at greater than 6 amps with a charger capable of supplying greater than 6 amps. Catastrophic battery failure is likely.
Unread 21-02-2010, 21:38
KGood's Avatar
KGood KGood is offline
Capt'n
AKA: Kevin
FRC #2134 (Aztec Pirates)
KGood is an unknown quantity at this point
2 amps (trickle charging) is more efficient if you have time to let it sit, but a quick charge at 6 amps is alright if you need it in a hurry. I wouldn't recommend over 6 though, mostly because we don't have a single charger that can go over 6.
2007: Rookie All-Star Award
2008: #2 of 54 in AZ Regional
Unread 21-02-2010, 22:37
DonRotolo's Avatar
Back to humble
FRC #0832
The battery prefers a slow charge over a faster one, so if you have the time, use the 2 Amp setting. At competition, time is of the essence, so we generally charge at 6 Amps. Over time, the difference in battery lifetime is measurable, but it's not very large.
Unread 24-02-2010, 04:45
code789 code789 is offline
AKA: Martin
FRC #2990 (Hotwire)
code789 is an unknown quantity at this point
2A is slower but more safe for the batt. 6A is faster but will damage the batt. depends on the situation if you have time i suggest you stick with the 2A
Unread 24-02-2010, 07:22
6 amps will not damage the battery. Higher than 6 amps might, 50 amps definitely will.
Unread 24-02-2010, 09:09
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
We usaly charge ours at 4amps with 6 bats we were ok for every mach. They dont take very long to charge.
Every day is a new adventure!!!
Unread 24-02-2010, 10:10
Racer26 Racer26 is offline
The 6A setting is fine for these batteries. As others have said, charging at higher amperages can and will shorten the lifespan of these batteries dramatically. We've charged some of ours on a 35A Fast Charge setting intended for car batteries for a few minutes at a time, those batteries aren't any good now, they wont last more than a minute or two at a time. One time someone accidentally left a battery on the 35A charge overnight... needless to say we returned the next day to a useless, exploded battery.
EDIT: Note that we don't do this anymore, we just HAVE in the past. I'm not sure that we have at all since that battery detonated.
Unread 24-02-2010, 10:15
Last year was unusually easy on batteries. I suspect they'll take a lot longer to charge after a Breakaway match than a Lunacy one.
Charging a System Zultraranger Pneumatics 7 05-02-2008 21:08
Charging the 7.2 Volt Batteries roboticsguy1988 Control System 43 17-01-2006 20:59
Battery Charging Box MikeDubreuil Electrical 17 22-04-2004 21:38
Charging Batteries like_a_fox Electrical 10 15-03-2004 17:57
charging backup battery Max Lobovsky Electrical 6 12-03-2004 10:24
