Go to Post The last 20% takes 80% of the time. Beware. - JVN [more]
Unread 21-02-2010, 20:17
Noamr Noamr is offline
FRC #1574 (Miscar)
Noamr is an unknown quantity at this point
PWM cables in Inventor
I was wondering if anyone has a clear explanation of how to create realistic PWM cables in Inventor.
Thanks in advance,
Noam
MisCar 1574
Unread 21-02-2010, 20:34
mpinventor19 mpinventor19 is offline
FRC #0514
mpinventor19 is an unknown quantity at this point
Re: PWM cables in Inventor
We literally just asked ourselves that question today. We had the idea of using the ribbon cabel comand to create the PWM Cables. If you have a better solution we would like to hear it but we also are still trying to figure out the Ribbon Cable command on inventor.
Unread 21-02-2010, 20:55
FRC #1574 (Miscar)
We would also appreciate some help with Inventor pneumatics...thanks
Unread 01-03-2010, 18:47
Terror Drone's Avatar
Terror Drone Terror Drone is offline
I am the Terror Drone, I like AL
AKA: Specs
FRC #1565 (Think Tank Tech)
Team Role: CAD
Terror Drone is an unknown quantity at this point
Well, you can get the 3d models of Bimba cylinders. And it's not hard to make a pneumatic piston, you just need to make the bores correct and then add details like threaded connectors and bolt holes, fitting inputs and such.
All your base are belong to us.
PWM cables in Inventor? acidrain2012 Inventor 0 14-03-2009 00:01
PWM Cables Mechanical Electrical 6 05-05-2008 21:35
custom PWM cables bruss6 Electrical 6 16-02-2007 08:33
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Cables zachriggle Electrical 3 04-02-2006 13:54
