Go to Post "What's this on the floor? 'Team 71 2005 strategy and design notebook'?" DRAT! I better call Bill and get this in the mail. - Gary Dillard [more]
Unread 18-02-2010, 00:47
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
Limit Switch
In java I'm trying to code a limit switch to my single motor called hunt
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Jaguar;
public class Pup extends SimpleRobot {
    private static final long TIME_DELAY = 1000; // in milliseconds
    RobotDrive drive = new RobotDrive(1, 2);
    Joystick leftstick = new Joystick(1);
    Joystick rightstick = new Joystick(2);
    Jaguar hunt = new Jaguar(4);
    Joystick spot = new Joystick(4);
    Joystick kicker = new Joystick(3);
    Watchdog fenrir = Watchdog.getInstance();
    Compressor fluffy = new Compressor(1, 1);
    void setUpRobot() {
        fluffy.start();
        fenrir.feed();
    public void autonomous() {
        setUpRobot();
        fenrir.setEnabled(false);
        while (true && isAutonomous() && isEnabled()) {
            drive.drive(1.0, 0.0);  // drive 100% fwd 0% turn
    public void operatorControl() {
        setUpRobot();
        while (true && isOperatorControl() && isEnabled()) // loop until change
            drive.tankDrive(leftstick, rightstick);
            hunt.set(kicker.getY());
            Timer.delay(0.005);
            fenrir.feed();
but i want it so that when it hits it, it will not go that way
Unread 18-02-2010, 09:36
Re: Limit Switch
What does "it" mean?
Unread 19-02-2010, 13:59
FRC #0581
Re: Limit Switch
Sorry I want the limit switch to stop the motor from continuing when hit.
Unread 20-02-2010, 21:03
Re: Limit Switch
Programming for a limit switch is straightforward. You just need to read the value of the switch and test for "active". Sometimes a limit switch will return a True when it's inactive, and False when it's active; sometimes it will be the other way around. You also need to know whether the motor would be moving "forward" or "reverse" when it hits the switch.
When you see that the switch is active and the motor is being asked to travel in the direction you don't want it to go anymore, set the motor value to zero. That's it. If the switch is not active, don't do anything special; that will let the motor move normally. If the motor isn't being told to go in the direction you don't want it to go, don't do anything special; that will let the motor go back away from the limit.
Unread 20-02-2010, 22:11
KayyPii's Avatar
KayyPii KayyPii is offline
FRC #1404 (SHOCKs)
KayyPii will become famous soon enough
Re: Limit Switch
In the API, theres a class called, DigitalInput. Once you create the class and specified with GPIO to keep track of, you can use the get() function to keep track of the state of the switch. Then you can use it as the boolean expression for the "if" statement.
=>"That hole you drilled is a little off."
=>"Don't panic, just make it bigger and put a washer on it!"
=>Eye ball once, and cut as many times as it takes
Unread 21-02-2010, 20:52
FRC #0581
Re: Limit Switch
What is the "if" statement for the limit switch.
Unread 21-02-2010, 22:58
KayyPii's Avatar
FRC #1404 (SHOCKs)
Re: Limit Switch
Say if you made a limit switch and named it switch.
DigitalInput switch = new DigitalInput ( 4, 1 ); //switch on digital side car channel 1
the if may look something like
if ( switch.get () )
//do something when the switch is not tripped
else
//do something when the switch is tripped
Unread 21-02-2010, 23:23
FRC #0581
Re: Limit Switch
else
Domo Arigato KayyPii-senpai and Alan-senpai
Unread 22-02-2010, 11:56
NullEntity's Avatar
NullEntity NullEntity is offline
AKA: Bryce
FRC #0093 (N.E.W. Apple Corps Robotics)
Team Role: Scout
NullEntity is an unknown quantity at this point
Re: Limit Switch
Slight tip:
Take out the true in
It's not a biggy at all, but you only want while(true) when you want it to infinitly loop. With other conditionals, it's pointless.
FRC Team 93 Alumni
limit switch solomason519 Programming 9 09-02-2010 08:50
Limit Switch Problem Boydean Programming 3 13-02-2008 16:32
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
limit switch wedellm Electrical 4 16-02-2007 13:01
