Re: cRIO-sidecar communication
Noah,
It sounds like the power supply wiring may have a problem. Did a wire pull out of the connector? Did someone remove the circuit breaker? Is it possible that you are not communicating with the robot? |
| digital sidecar J1 pinouts (cRIO connection) | stevethetinker | Programming | 0 | 09-02-2010 21:34 |
| Changing Crio Digital Sidecar input slot from slot 4 to 5 | Trevor_Decker | Java | 9 | 28-01-2010 12:29 |
| Netbeans 6.8 Ftp to cRIO communication issue | mark.amber | Java | 4 | 20-01-2010 17:10 |
| Sidecar Debug | NinjaSpawn94 | NI LabVIEW | 6 | 07-02-2009 10:48 |
| Digital Sidecar Resistor | NinJA999 | Electrical | 5 | 30-01-2009 19:53 |
