Go to Post Robotics season has monopolized my time for the past several weeks so I have not been keeping up with Segway news lately - Stu Bloom [more]
Unread 21-02-2010, 22:28
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Laser Pointer on Bot for alignment only: Legal or illegal?
I have to reiterate what dtengineering said. Just fashion a mechanical "sight". Sheesh.
How is this any more complicated than using a good old #2 pencil to draw (or a rusty nail to scratch) two small dots/lines on the frame of the bot and then lining them up with a 3rd spot (on the field or venue) each time you set the robot down on the field?
Use as many pencil marks as you like in order to make use of as many reference points as you like.
If you care to, use colored pens to create sets of alignment marks for each 3rd of the field, and for red and blue alliance possibilities.
I dare say that I think that the accuracy you will get out of sighting along a few widely spaced reference marks on the bot will equal or exceed anything you could get from trying to connect a wiggly little pointer (with loosely installed guts) tightly enough to the bot's frame to be able to stay aligned after the pounding of a few matches.
Blake
PS: A team that really wants to create a really sexy set of sights will solder/expoy together a few tiny metal tubes (pointing in different directions) gotten from their local hobby shop, and will and attach them to their bot, instead of using mere pencil marks.
PPS: Please pardon me in advance if this message seems to be uninspiring - There is a time for being inspired to use lasers, and a time for remembering and appreciating the simple elegance of a Kentucky long rifle. This seems to call for the latter.
Unread 21-02-2010, 23:57
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
<G11> ROBOT Alignment Devices - Alignment devices (templates, tape measures, laser pointers,
etc.) that are not part of the ROBOT may not be used to assist with positioning the ROBOT.
Violation: TEAMS that use external alignment devices to position their ROBOT will have
their ROBOT arbitrarily repositioned by a referee before the start of the MATCH.
Emphasis mine.
so attach a tape measure that you can extend to know correct placement then will retract and stay retracted. Or if you can get a laser pointer by R02 then you should be able to use that.
As G11 only disallows EXTERNAL positioning devices or jigs anything that is part of the robot meets all other rules specifications and weights should be allowed.
Unread 22-02-2010, 01:29
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is online now
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Thank you team 190. MOH Goat strikes again!
Join 1089 for a NJ Laser Tag Celebration! BandChick General Forum 4 03-03-2009 19:39
Aiming that remote: Laser pointer allowed? efoote868 Rules/Strategy 9 02-03-2008 21:01
Illegal or Legal? Pyro648 Technical Discussion 7 26-06-2007 14:40
Are 2 RC contorllers on 1 bot legal? Tottanka Rules/Strategy 10 13-01-2007 21:17
laser pointer 1574aviad Technical Discussion 9 20-02-2005 20:25
